Change advanced parameter zen72
That won't work with Rule Machine. The configure command does not accept parameters, so you should see an error in "Logs" when that is executed. I'm not familiar with the "Advanced" drivers for the the ZEN7x devices, but others may need a configure or refresh (using that driver) before device-specific options are displayed, so I might try that if it haven't.
Otherwise, in general, the Basic Z-Wave Tool can be used to set parameters for any device. Just temporarily switch to that driver, run the "Set Parameter" command with the appropriate values (the manual should have all the información you need), the switch back to your normal driver.
