Not directly, no. This HAS worked OK as a night light for my daughter. Once she set the color she wanted (manually pressing on it to change the color) it has been fine for her. Responds to Rules to turn on at Sunset and off at Sunrise (plus I may have it set to turn off if her main room light is on, I forget). It DOES respond to on/off/dim commands and DOES have a battery. I cannot tell how well it works as a ZigBee repeater anymore (I have too many things that do that now).
As far as direct alternatives... Not really. It somewhat depends on what you are looking for. There are some outlets and repeaters (Aeotec Repeater 7 has a white LED that CAN be controlled) with LEDs that can be controlled (usually with community-written drivers). Not really what they are MEANT for but it kindof works.
If you want something with a battery there are workarounds like USB-powered ZigBee LED strips. Pop one on a USB battery pack (that provides power while charging of course) and it works just fine. I have a GLEDOPTO model (not sure about others)
