Just picked up a couple of these keypads. Got everything working except arming for night mode. I'm getting the below error. Anyone got any ideas?
errorgroovy.lang.MissingMethodException: No signature of method: centraliteKeypad.armNite() is applicable for argument types: (java.lang.String, java.util.LinkedHashMap) values: [physical, [-1:[code:0000, name:not required]]]
I hit the night button. Top right then my 4 digit pin. The lights will blink across the top, left to right twice then beep. After it just defaults back to disarmed. Never arms. This happens on both.
Not sure if it matters. But this isn’t the Lowe’s version. It’s this one.
It’s not a huge deal. I have a rule set up that when it is armed home from the keypads it flips to night mode. When that happens the night button does light up.
I have the same issue, armnite() not found when trying to a night from centralite 3400.
I'm at your disposal in case I can do something to debug it.
Has this been looked into any further. I have both arm home and away working as well as disarm but when hitting night mode from the keypad nothing happens
Has it been fixed with 2.0.5? I cannot upgrade due to Xiaomi devices unfortunately, but I don't see it in release notes so I think should still bugged..
