We have pushed a hot fix release, Version 2.0.8.109.
This release includes a fix to HSM for exit delays for Arm Home and Arm Night, as well as resolves issues with keypads interfacing to HSM. It should be noted that Iris keypads, the ones with a Partial button, have to be selected to either arm Home with Partial, or arm Night. If you go into the auto arm settings of HSM and remove your keypads completely, and then set them up again, this choice will be offered. The Centralite keypad with 3 b…
Partial and Arm buttons have been discussed but the Panic button hasn't. The panic button is number 1 and can be used in RM or so I hope so.
It does work in ST and I have a piston setup to sound the alarm and turn on all lights and also simulate a actual break in to set off my security monitoring app.
Maybe someone can test that and see if it works in HE.
If panic button is available on the keypad, there should be an option on the device edit page to enable it. Why don't you test it out if you're curious. LOL
As I said I use it in ST not HE. Read again.
Which driver are you using in ST?, and which keypad, exactly?
https://docs.hubitat.com/index.php?title=SecurityKeypads
Iris keypad 3405-L
And it also works using the rboy Enhanced ZigBee Keypad Lock
that device doesn't have three arming mode buttons.
by default partial == armHome, via HSM it can be assigned armedNight.
on == armAway, off == disarm
panic is supported, via the keypad and capability alarm
Ok... I was just pointing out that the Panic button does work on that keypad as I didn't see any mention of it being able to use.
motion sensor 1's button # 1 pushed?, I have no idea what that is.
what's the actual physical button name on the device that this refers to?
yeah, its usable, most don't as it's super loud and super annoying...
Yup but in a pinch its certainly going to make a intruder run.
It's button 1 on that keypad
button 1 doesn't do anything, whats kicking this off is the devices motion sensor, I guess RB has mapped that to button 1?
The Iris versions of this keypad all have a panic button, are you saying that with RB's driver the panic button does nothing?
vjv
April 1, 2019, 9:01pm
12
I suppose any of your codes started without number one.
the keypads do not send the numbered buttons one at a time, only after 4 have been entered, then they get sent.
I'm saying that button 1 (Panic) works in both DH I posted.
vjv
April 1, 2019, 9:11pm
15
Yes, I just read the rboy driver, it works like a lock, but it's a keypad.
you mean that the physical button "panic" on the device reports as button id #1
I thought you were telling me that the physical numeric button #1 , reported a button event...
right ST has no capability for keypads, we do, so aside from lockCodes these share nothing with the lock capability.
Sorry for the confusion. I meant to word it like you did below.
Correct
system
Closed
September 22, 2022, 6:50pm
19
