We have pushed a hot fix release, Version 2.0.8.109.
This release includes a fix to HSM for exit delays for Arm Home and Arm Night, as well as resolves issues with keypads interfacing to HSM. It should be noted that Iris keypads, the ones with a Partial button, have to be selected to either arm Home with Partial, or arm Night. If you go into the auto arm settings of HSM and remove your keypads completely, and then set them up again, this choice will be offered. The Centralite keypad with 3 buttons doesn't have this issue.
There was a small UI bug in Motion Lighting when Delay Per Mode is selected, now fixed.
The Group virtual device name (label, actually) will now change if the name of the Group is changed.
