Since 2.0 I am unable to update driver code, receiving the following error when I click save, having changed a single line of code.
A problem occurred while trying to acquire a cached PreparedStatement in a background thread. on line null
Could it be related to the 1st bullet in this post? Or are you using that method to change your driver code?
I did not use the import feature. I just changed the code manually.
@doug I went to a driver code and added a return. Did a save, it worked.
Can't trivially duplicate your error.
Is it just that driver or all drivers?
What happens if you copy the code and try saving it as a new driver?
Have you rebooted and tried after a reboot?
Since I copied the code and created a 'new' driver. I now have a duplicate that gives an error 500 on delete.
@bobbyD Still dead in the water.
Plus I now have duplicate drivers I can not delete. I can therefore not use them because I can't tell which is which when installing.
Attempting to delete anything results in
