This morning I have added my wifi id and password into hubitat. Then they ask me to reboot and since that my hub has never reboot. I have try to reboot, soft reset ... through the port 8081 but nothing work. When i do the soft reset i have a message : unknown error occured.
Please help, i dont have any idea what to do.
PS: i have a backup.
The hub doesn't have built-in wifi, which is used when you use an OTG adapter and plug a wifi dongle in the hub. Try pressing the little circle button on the bottom of the hub with a small pin. It should be near the edge and is the only circle hole on the bottom, the rest of the holes should be small squares.
Could you please elaborate what are the symptoms of your problem? Additionally, please send me a private message with your hub's Hub ID or MAC address, so we can further investigate.
