Can't pair any Zigbee devices on C-8
@NotBernard65 - In case you haven't seen it before, you'll find your hub UID under Settings>Hub Details:
From what I've seen, if you use 'Rebuild network' all (including pairing) goes well until you next reboot the hub. There is however a buggy side effect (which apparently no one has reported or reproduced except me.... @bobbyd was said he was going to try but hasn't reported his results).
Upon rebooting the hub after having done 'Rebuild', links to neighbor repeaters (I've tried this with one and two repeaters) no longer function (hence you lose connectivity to any device that isn't a directly connected end device of the C-8). You can fix this in one of the following ways:
  • Rebooting the hub again
  • Rebooting the Zigbee radio
  • doing nothing but wait for 40-90 minutes.
Done
Tip on channel 26 helped me make some progress. I can at least now pair the Sengled bulbs I have. I can't control them, but it is something...
@mike.maxwell following on from our conversation via DM to help me with my issue I raised a return of my C-8. This was way back on the 6th of April, I got an initial reply saying ā€œThe issue you reported has been referred to our engineering team and we will reach out to you if additional details about this incident are neededā€. I replied (mentioning yourself) explaining that this had already been done….. No reply from them since.
Whilst I can’t complain re. the support on this forum (both from Hubitat and the wider community) the wider customer service is very poor. I’ve had this unit for weeks now and it’s never worked properly.
All I want is a working replacement please, which I don’t think is an unreasonable request?
go to Warranty – Hubitat Support
That’s exactly what I did. They responded with the reply as per my last post. I replied back and then nothing…… :frowning:
@bobbyD
Please check your email, your case has been processed.
