When I try to open the thermostat scheduler for my Rheem water heater, I am getting the following error.
This is what shows in the logs.
This is on a C5 currently running 2.3.4.119
The scheduler seems to still need working and setting the temperature. It just appears that I can't edit it. Wondering if there is a way to fix this without removing and re-adding the app so I don't lose my scheduler settings.
Please show the Current States of the thermostat involved with this, from its device page.
I suspect your driver is out of date. If that's true, there is an easy fix.
Is this what you're after?
Heating Setpoint of 110, you running a sauna?
Yes, you have an out of date driver. If you fix the device, this error will clear up.
See this:
That driver is out of date, and its author should update it.
The supportedThermostatModes and supportedThermostatFanModes attributes have bad values. For each, the individual words need to be in quotes. To fix it follow these steps:
Temporarily change the driver to Virtual Thermostat, hit Save Device. Then put this string in the command box for setSupportedThermostatModes
["auto","off","heat","emergency heat","cool"]
and hit the command button. Then put this string in the setSupportedThe…
You only need to fix supportedThermostatModes (not both), and it should be ["off","heat"]
system
Closed
December 20, 2023, 7:04pm
6
