IT's only 30 feet from the hub. Didn't think it would be a issue.
You could try a repair, make sure the lock node shows up in the list of repaired devices.
ok
It never repaired node 50. It stopped at Node 42 so it missed a few zwave devices.
sys:12018-11-09 17:22:15.101:infoFinished Z-Wave Network Repair
sys:12018-11-09 17:22:04.563:traceZ-Wave Node 42: Repair is done.
sys:12018-11-09 17:22:04.553:traceZ-Wave Node 42: Repair is requesting node neighbor info
sys:12018-11-09 17:22:04.552:traceZ-Wave Node 42: Repair is adding return route
sys:12018-11-09 17:22:04.551:traceZ-Wave Node 42: Repair is deleting routes
sys:12018-11-09 17:22:04.550:traceZ-Wave Node 42: Repair is requesting device associations
sys:12018-11-09 17:21:55.583:traceZ-Wave Node 42: Repair is updating neighbors
sys:12018-11-09 17:21:54.921:traceZ-Wave Node 42: Repair setting SUC route
sys:12018-11-09 17:20:20.166:traceZ-Wave Node 42: Repair setting SUC route
sys:12018-11-09 17:20:19.812:traceZ-Wave Node 42: Repair pinging
sys:12018-11-09 17:20:19.811:traceZ-Wave Node 42: Repair starting
Missed 43, 45, 46, 48 and 50
Well shit.. I get status if I use the lock to program codes, lock/unlock but not the other way. Seems the lock is communicating only 1 way.
So I programmed slot 3 manually at the lock keypad and tested the code and it worked. Went back to the device and clicked on retrieve codes. New code did not show up and using the new code I got this in in the logs.
dev:12502018-11-09 17:51:40.524:infoBack Door Lock was unlocked by unknown codeNumber: null[19-a]
I just wanted to bump this thread as I just purchased a half dozen Kwikset 914 locks myself and I'm hitting the exact same issues. Here's the fingerprint:
After getting the lock paired communication is very unreliable. I can add codes but "delete" doesn't seem to work. It successfully deletes the code from the lock (Because it no longer unlocks it) but Hubitat still shows the code assigned to the lock. They also don't seem to work with LCM at all.
-Jeremy
just replying to follow. my hubitat will be here on friday and i own the same locks
Replied to you in another thread. Make sure you've clicked "Configure" after manually changing the driver to Generic Z-Wave Lock.
Related problem - I had my Kwikset lock in ST but that hub is down as I move over to HE, but I cannot get the locks to be discovered. All the other Zigbee stuff, but I have two of the locks and neither one will appear in Discovery. Any suggestions?
Welcome to the Hubitat Community!
If these are Zigbee locks, factory reset them and pull the batteries for 30 sec.
You may need to pair closer to the locks. Normally pair in place is recommend, but locks are a different animal. Make sure you have adequate repeaters in range though.
https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Zigbee_Mesh
https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Z-Wave_Mesh
Reset or exclude first.
Move the lock module or the HE hub close to each other. Usually less than a couple of feet.
Go into the HE Z-wave setting and click on all devices secure mode.
Turn on discovery and follow the inclusion of the lock.
No luck. That's what I've been doing - the exclusion and re-scan. I've even gotten the locks to within a foot of the hub (even though I've got mesh nodes within a few feet of each lock position).
Only think I haven't done is a full factory reset because I'd rather not have to reprogram them. Plus I can't find anything in the manuals about how to do the full factory reset.
I have one of this lock and it's not easy to get it working but it does work. Just be sure it's excluded by looking at the blinking led. Here's the manual in PDF from kwiset.
It doesn't take very long to reprogram the code. Maybe a couple mins each.
I always remind people to make sure they are pushing the correct button, too...
There have been at least 5 times I've helped people w/Kwikset locks only to find out they were pushing the program button instead of the "A" button.
Not saying that applies here, just thinking out loud.
Well, I was pushing the right button, thankfully, but it was just an extra reset and rescan. Finally got them in. Thanks. Now to convert over a few wifi switches I can't integrate and all will be well!
Did you have to reset the lock at the end to get it included? Either way, glad you got it working
Yes, but something weird with one of the two and it took a lot longer - I think it's how my mesh is set and I have a weak spot to fill. But both are working great now.
