I have my Tesla in Hubitat, and can see the state of the charge. I have Notifier setup to notify me when the battery gets low, and it is not working (or I am not getting the notifications, will have to look in the logs actually).
It was on once per day, but I have changed it to once per minute to try and troubleshoot.
It seems like it only reports when the threshold is crossed and the once per day or minute setting seems to be for subsequent notification on other devices that day. Did you have this setup when the charge was above 60% and it didn't notify when it went below?
I have had this setup for a while and just forgot about it, since it never worked. Made it to work with 7% battery so this reminded me today that I wanted to get it working.
Found this, Push Notifications not working and when I follow the steps to push notifications to my phone they work. So it appears to be an APP (notier) not sending the notifications.
Has the level changed at all since you put in the notification? The notification will only go out when the app receives an event, meaning an update to the battery level.
Do you have a link to the driver you are using? I am suspecting that the battery level is being sent a string and not a number. That's why the notification app can't read it correctly.
Thanks, I gave that a try and will see what happens. Going to drive the car in a few hours so will set the notification to be lower than whatever state of charge I have to see if I can get it to trigger and fire a notification.
