Haha... WAN port has little piece of electrical tap over it.
I also like having a wireless backup. I've had the radio go out on an internet company's router but not the actual connection before. Admittedly, that was some time ago, but now I'm ridiculously reliant on it. Switch would be cheaper.
I used to do what youâre doing and it was the cause a lot of problems I found out later. It may be whatâs causing your problem right now. You might want to take it out and just connect directly to your ISP modem. See if that works.
Regarding your setup, are you following these directions? The hub light stays blue until your hub is registered. Then it will be green. Make sure you go through the entire process of setting up your account with the verification email step too. If you donât verify the account, itâs not going to allow you to register your hub.
I unplugged it early on, and it has now died - hence asking for a recommendation. I've never had issues using it as a switch, but figured better check.
I've followed all the directions, and it's glowing blue but not showing up in the router.
Unless you have the "router as a switch" configured properly... If you have(had) the HE connected to it, it will give the HE an IP address... and it will not show up in the ARP table or DHCP table for the main router...
Wait. It just showed up on the router, but showing as inactive. I've pinged it successfully but the panel still won't find it, even with the Mac address.
I donât think itâs doing a database backup since itâs not setup, but you should know that this is the database backup time. Might be a factor.
Best to get some rest and look at this with fresh eyes tomorrow. Donât let yourself get run down. These are not good days to pull all nighters. We all need strong immune systems right now. Have a good one
