Can't Delete Global Variable
I previously created a global variable with the wrong name, @Min_Vent_Save_Level, instead of "Safe," and then I tried to delete it. Although it disappears from the webCoRE dashboard interface, I still see it when I do a dump of global variables:
If I create the variable again with the same name, it will then show the type, but if I delete it again it still remains as above.
I've tried clearing the cashes, logs, everything, but the old variable remains in the global variable dump.
Is this a bug, or does anyone know how I can get rid of it?
What is that?
It's one of the buttons in webCoRE to see your global variables:
I have searched and have no idea where that is.
There may be other references to it but this is the one I found first...
Thank you! Rebooting eliminated the old reference.
Worked perfectly. Just the information I needed. Thanks to both of you.
