Cannot find hub
Hi everyone,
I'm new to the Hubitat family and just received the hub. After several hours of trying and browsing community posts and searching the internet, I still have not been able to find a solution.
The hub light goes green (and yes, plugged in the LAN cable prior to switching it on and in one of the correct ports).
On my laptop I tried:
And pretty much all possible combinations with the above.
I also tried using a mobile phone and a tablet (I however was not able to continue as it did not allow me to enter the postal code).
Any help is greatly appreciated.
Just put in the first block of the post code. i.e. IP27
Alternatively you can leave it blank and manually input you Long/Lat information.
Also select Europe/London as your Time Zone. (I'm assuming you are in the UK as you mentioned postcode).
BTW, welcome to the mad house. :wink:
Just for the sake of argument, if you enter http://hubitat.local into your browser what do you get?
Thanks for your answer using a mobile device. Unfortunately, it does not seem to work on my end. I'm only allowed to enter numbers btw.
What is very odd is that the mobile app even says "a hub was found to claim at:" while I had the hub disconnected.
This is what I get: "### Corrupt database found
Hub cannot continue. Please try the following actions:
Not what I was hoping for but progress, if you click the reboot link does the hub reboot?
The light on the hub went from green to blue. And subsequently green again.
Okay rebooted. Does http://findmyhub.hubitat.com work now?
If I try to reboot using the diagnostics tool I get the following
It does not.
Might have to do a factory reset, but letโ€™s tag @support @bobbyD and see if they want you to try something else first.
Thanks!
If error code 401 appears isn't this an indication that you need to choose logout (assuming you get that option of course) and then sign in again.
correct - Login for the Diagnostics Page has timed out. Could try hubitat.local again to see if it gives the full menu also.
@support_team can someone help him out?
I logged out and in again in the diagnostic tool.
Hubitat local shows:
Since this is a new hub, letโ€™s try the soft reset. It should repair the database.. Donโ€™t worry about restoring a backup when it finishes.
If it's a new hub with no devices/apps defined I would try a soft reset.
What @thebearmay said above. :wink:
When i click soft reset I get:
