Hello
I run sinopee 1400 thermostat for heated floor and also the honeywell t6 for central heating
On both thermostat, i can’t update the temperature setting, the only thing i can do is change the mode (on/off/cold,heat, etc…) so seems like there is something wrong with the app since all thermostat have the same problem
Ive checked other discussion and ive tried everything (verify that the device match, update the system, delete and re-pair the device, reboot the hub)
The honeywell worked ok after rebot the hub but the problem came back after 3 days
Any idea how to fix this ?
I see also many error on the log section
I use iphone app
