Can not create new custom command
When I click "New custom command..." I get:
Then when I click "Logs" I get:
Tried 3 different web browsers as I saw that suggestion somewhere else. Same problem.
Saw another user with this problem so thought maybe it was more than just me:
EDIT: This in logs:
[app:227](http://192.168.13.46/logs#app227)2018-12-06 10:22:34.850 am [error](http://192.168.13.46/installedapp/configure/227)java.lang.ArrayIndexOutOfBoundsException: 2 (addCustomCommandPAGE)
This should be fixed in an upcoming release. Should not effect the creation just exiting out of the app, correct?
I can not even get in to create a new command.
Mine loads fine. It is just saving it sometimes causes the appearance of an error but the command/rule still gets saved correctly.
Had the same but just open and save again and it works.
