Can anyone get the Device Firmware Updater to work?
I'm trying to update a Zooz ZSE42 (battery operated) leak sensor to new firmware. It starts out okay and looks like this:
When I click the Start Firmware Update button, it looks like this:
Then I click the device button 4 times (which wakes it up) and it looks like this:
At this point it does nothing. I can keep doing the waking up routine and nothing happens. The whole thing is just hung at this screen forever.
What am I doing wrong? I there any issues with this built-in app under C8?
Try disabling the device prior to the update -- this trick usually works...
Device Firmware Updater with Zooz device - :toolbox: Built-In Apps and Drivers / Built-in Apps - Hubitat
This should be unnecessary, but I always clear out the Updater app's files, then remove it, then reload it every time I do an update. Just start totally fresh-&-clean every time you use the Updater app -- it seems to help keep it clear and smoother.
Just to double check, it's not paired with security, is it? If so, this will not work.
