I have fluorescent light fixtures in my shop that were connected with Jasco Binary Switch (Z-Wave+) on my older z-wave platform, TraneHome (Nexia w/BR100 Controller).
Since the HE7 inception that I bought a month back, I excluded and then included each light fixture to Hubitat but have now run out of the older black outdoor plugs and want to use a simple, smart plug. Are the new smart plugs compatible with fluorescent on/off style fixtures?
Do you really intend to dim your fluorescent lights? You’re probably best off using a plug that just switches on/off, not one that dims.
You have to make sure they are relay style contacts in them, you will usually hear a click when they change state. This kind of smart plug will be ok for fluorescent fixtures. I know the Ikea Zigbee ones have a relay and are compatible (also good repeaters).
If you want to stick with ZWave, check the Zooz line, most on/off devices use relays, if you are not sure just ask them, they are usually very responsive.
I am not, just asking if a smart plug would work. If it’s incompatible, I’ll use a similar plug like the Jasco.
Thanks, I’ll check out Zooz. Going all out on z-Wave, already too many Wi-Fi devices on the network, particularly cameras. Don’t find much in the way of Z-Wave cameras.
A plug that only turns on/off, with a relay inside, as @nclark mentioned, yes.
A plug that is a dimmer, no.
I've had good luck with a Leviton DZPA1 Z-Wave outlet/plug.
The Leviton DZPA1 is a Z-Wave Plus enabled plug-in outlet is ideal for any residential setting that needs remote ON/OFF switching of appliances, motor loads up to 1/2 HP, or freestanding lights up to 1800W, including Incandescent, LED, Fluorescent and Compact Fluorescent loads.
Check here for more options: List of Compatible Devices:
Z-Wave Plugs
Aeotec (Aeon Labs) | Smart Energy Switch | DSC06106 | Outlet / Plug | Z-Wave | Aeotec Smart Energy Switch | Show | |
Aeotec (Aeon Labs) | Smart Switch 6 | ZW096-A02, ZW096AU, ZW110-B09 | Outlet / Plug | Z-Wave | Aeotec Smart Switch 6 | Show | |
Aeotec (Aeon Labs) | Smart Switch 7 US | ZWA023-A | Outlet / Plug | Z-Wave | Aeotec Smart Switch 7 US | Show | Amazon |
Dome | On/Off Plug | DMOF1 | Outlet / Plug | Z-Wave | Dome On Off Plug | Show | |
Dragontech | Plug-In On/Off Z-Wave Plus Appliance Module | PA-100 | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | ||
Eaton (Cooper Wiring Devices) | Plug-In Module | RF96APM | Outlet / Plug | Z-Wave | Generic Z-Wave Plus Outlet | ||
Eaton (Cooper Wiring Devices) | Wireless Outlet / Plug | RF96APM | Outlet / Plug | Z-Wave | Generic Z-Wave Plus Outlet | Show | |
Eva Logik | Outdoor Plug | Outlet / Plug | Z-Wave | EVA LOGIK Smart Plug | Amazon | ||
Eva Logik | Smart Plug | ZW36, ZW37 | Outlet / Plug | Z-Wave | EVA LOGIK Smart Plug | Show | Amazon |
Fibaro | Wall Plug | FGWPB-111, FGWPB-121 | Outlet / Plug | Z-Wave | Fibaro Wall Plug | Show | Amazon |
GE/Jasco | Smart Outlet | 14267 | Outlet / Plug | Z-Wave | Generic Z-Wave Plus Outlet | ||
GE/Jasco | Smart Outlet | 55249 | Outlet / Plug | Z-Wave | Jasco Z-Wave Dual Outlet | Amazon | |
GE/Jasco | Smart Outlet | 55256 | Outlet / Plug | Z-Wave | Generic Z-Wave Plus Outlet | Amazon | |
HomePro | Outlet | ZRP110 | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Show | |
Inovelli | 2-Channel Plug | NZW37 | Outlet / Plug | Z-Wave | Inovelli 2-Channel Plug | ||
Inovelli | Outlet | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Show | ||
Leviton | Plug-in Appliance Module | DZPA1 | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Show | |
Leviton | Tamper-Resistant Outlet | ZW15R | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | ||
Minoston | 2-Channel Plug | MP20Z | Outlet / Plug | Z-Wave | Inovelli 2-Channel Plug | ||
Minoston | Mini Plug-in Outlet | MP21Z | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Amazon | |
Minoston | Mini Power Meter Plug | MP21ZP | Outlet / Plug | Z-Wave | Minoston Mini Power Meter Plug | ||
Monoprice | Outlet | 15654 | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Show | |
Monoprice | Z-Wave Plugin On/Off | 11995 | Outlet / Plug | Z-Wave | Generic Z-Wave Outlet | Show | |
Monoprice | Z-Wave Plus Smart Plug and Repeater with 2 USB ports | 27481 | Outlet / Plug | Z-Wave | Zooz Power Switch | Show | |
NEO | NEO Coolcam Power Plug | NAS-WR01ZU | Outlet / Plug | Z-Wave | Neo Coolcam Power Plug | Show | |
New One | Mini Smart Plug | N4001 | Outlet / Plug | Z-Wave | Generic Z-Wave Plus Outlet | ||
Sunricher | Smart Plug | ZV9020A | Outlet / Plug | Z-Wave | Sunricher SR-ZV9020A Z-Wave Smart Plug | ||
Telldus | Outlet Switch | TZWP-100 | Outlet / Plug | Z-Wave | Generic Z-Wave Smart Switch | Show | |
ZLINK | Appliance Switch | ZL-PA-100 | Outlet / Plug | Z-Wave | Generic Z-Wave outlet | Amazon | |
Zooz | Smart Plug | ZEN06 | Outlet / Plug | Z-Wave | Zooz Power Switch | Show |
Good enough, thanks for the clarification.
Could probably work for small space heaters too?
Don't see why not, as long as it's under 1/2 hp.
With a sensor and this great app.
Good to know. I haven't done anything with a virtual device yet so I could possibly set it up with the space heater.
