C8 to C8 Pro migration - Zigbee nightmare - 2.4.3.164
I really didn't want to make another thread, but retried the migration today and everything seemed to go well. Booted up, installed the latest update, etc. All working except for Zigbee. PAN id is populated, I see most devices have messages increasing too. Zigbee graph shows devices talking thru repeaters. I do see a mystery 0000 device as well.
Channel and power is the same as the old hub.
Old hub was on 2.4.3.164, updated new hub to same version after it was up and running.
Some battery devices are updating motion/temp, etc. Some mains devices update if I turn them on manually. But I cannot control anything from the hub.
I let it soak for over 3 hours, no change. reset zigbee radio, then powered down hub, waited and back on.
Waited a bit, no change so I power cycled all mains devices. No change.
Just tried a rebuild zigbee network about 45 minutes ago. No change
I know the getchildandandroute endpoint has limited utility these days, but I notice all my repeaters have an outcost of 0.
Also FWIW, zigbee channel scan comes back with all zeros for everything.
7 hours post migration now. Still nothing. Wife is in a state of panic I just tried the migration again, no change.
@bcopeland @gopher194 @bobbyD Anyone?
Did you update the Zigbee radio firmware on the C-8 pro before migrating? I was prompted to do this on mine, but only when I tried just restoring everything from a fresh cloud backup, trying to do a migration just sat there and didnโ€™t do anything. I just migrated 110 Zigbee devices and 30 something z-wave from a C-8 to C-8 pro a few days ago on .164 and this was the only Zigbee hiccup. I did it via a cloud restore to the new hub after unplugging the old hub.
You also mention resetting the Zigbee radio, which would require restoring the Zigbee radio again for devices to function.
It didn't prompt me to update the radio firmware on the c8
I did the same cloud restore deal.
I meant to say I tried rebooting the zigbee radio (thru zigbee settings page)
Have you performed a controlled shutdown of the new hub, unplugged the power for about 10s, and then powered it back on? This is the only way to truly reboot the Zigbee and Z-Wave radios (IIRC) so it might be worth a try.
Yeah tried that too. Actually twice. :pensive:
Also power cycle all my mains powered devices too.
I updated the firmware of both radios, and used zip for zwave, since that is what the old hub was using. Then restored the cloud backup with both radios checked.
That's not good. Unfortunately, there is no magic migration failure fix. Some hubs may not be able to migrate and a manual migration may be the only solution. I would try to go back to the C8 for the night and submit a warranty case. Based on the details you shared, your new hub may be dealing with a hardware malfuntion. If that's the case, we will send you a replacement right away.
I purchased thru Amazon, I assume I need to go thru them vs filling out the form?
[edit] I see it says amazon too. Sending the form now.
Just go to support.hubiat.com in a browser and click on warranty.
That said, I would retry the migration and make sure that the zip radio is checked on restore.
Ah I do see that on the warranty page about amazon now..
I did retry the migration last night with the same results.
Old c8 back up and devices working again. filling out warranty claim now..
You mustโ€™ve gotten a defective hub. I did the migration a few days ago and every radio device was immediately working. Except for some meshed device issues that I messaged @gopher.ny and @bobbyD about, it was not much different than doing an update. I hope your experience is similar with your replacement hub.
Me too, no migration issues and it went incredibly smooth. I was throughly impressed. I came from a C7 to a C8pro (270 devices).
Sorry @scoob8000 I don't have any sage advice.
Scooby always did run into crazy experiences...likely a ghost in his new hub, it happens. :wink:
I brought the C8 pro to work so I could boot it up to factory reset for the warranty process and boot it without interfering with my home stuff.
Just for giggles, I did a FULL reset on it and after I powered it back up I let it do a firmware update before doing anything else.
After the firmware update I tried a zigbee channel scan. Sure enough it's returning stuff now.
So again for giggles, I restored a fresh C8 cloud backup to it let it reboot, and again the zigbee channel scan still works.
I'm tempted to power down the C8 at home and let it boot and see if it works. Think it could have just been something corrupt with the zigbee radio the full reset fixed?
Just wanted to share, I will post back if I try it and my findings...
Thanks for the update. Just for clarification, the full reset process doesn't do anything different than you going into Zigbee Details page and select reset, or simply restoring a cloud backup. All 3 perform the same radio reset.
Interesting. Unless something else changed.
I'll test it out at home over the weekend and report back.
No such luck bringing it back home. Zigbee channel scan still all zeros and all repeaters are outcost:0. Guess we'll go ahead with the warranty swap. :frowning:
Channel scan almost never works for me. Once in a while I can refresh and get it to work. It is not an indication of any operating status of your own Zigbee network.
How long does the warranty process take? It's been a week since I got the automated response from filling out the form and haven't heard anything else.
