I do not believe the HE built-in 'Lutron Integrator' app is a LAN integration app because there is no reference to the HE hub's IP anywhere in the Lutron IOS app.
You can disable them if you want; Lutron and Hue just don't need to be. Saying to do it for everything was easier than giving a list, though most of the "offenders" are cloud. (But it can still be a good idea to eliminate lots of load on your hub trying to reconnect everything at once the first time after you restore the backup; if you go one-by-one, as suggested, you'll have an easier time finding which thing was a problem if there is one.)
Disabling devices (disabling its driver from running) is similar to apps--select the "X" button in the top right of the list to hide/show the "Disable" column first if you don't see it.
