Every time I reboot the hub, all three of these plugs become unresponsive. I have 3 plugs setup + 2 hue sensors. Hue sensors work fine. I'm seeing activity in the 'Msgs' column (Zigbee Details) for hue, but 0 for Sengled.
Once I go to Settings -> Zigbee Details and hit 'Rebuild Network', the plugs work again (and the 'Msgs' count instantly increments to '1' for each device).
Is this a bug I need to report or am I missing something here? Thanks.
in leu of clicking rebuild network after the next reboot can you try manually turning the outlet on and off from the actual device?, if that doesn't work can you try unplugging it, then plugging it back in?
Then let me know the results of that...
Ok, I'll treat this as a one off for now. I'm configuring another new C8 hub for someone with these plugs and will see if the issue persists. For now, I've worked around the issue with @rlithgow1's suggestion. Thanks.
Agreed - I do my research on this forum in advance (like you) on what to buy and saw the Sengled were recommended as well; which is why I was surprised I got the results I did. I do understand these things can be a beast to troubleshoot since everyone's environment is different.
Keep me posted on your progress @velvetfoot and how the install went for you. I will do the same.
I just tried setting these plugs up on a brand new C8 hub and the same behavior occurs - they go unresponsive after a reboot until I rebuild the Zigbee mesh network. For now, I've worked around the issue by setting this toggle:
@mike.maxwell - Anything I can do to help further diagnose this issue?
I don't know what's going on, but i don't think it's specifically these outlets.
I tested the newer version (E1C-NB7) of these a few weeks ago and wasn't able to replicate the issue.
Were there other devices on this C8?, what channel and power settings?
And the proximity to the hub?
