What I learned back in the day: A transmitter needs to be able to shed it's power to the antenna. No antenna could "blow up" your transmitter.
Seeing the hub is a transmitter for zigbee and zwave, I powered it down when replacing my antenna.
Don't think it will cause serious damage if you do it quickly, but power down just to be sure is my advise.
Why did u swap it?
I switched to an antenna that @bertabcd1234 testd and had good results with. Also improved my Z-Wave results w/the C8.
Posted about it here:
Thanks for the replies, @fanmanrules and @aaiyar. Does make sense that the transmitter needs to shed its power. Pretty sure I changed my Z-Wave antenna w/out powering down and nothing blew up, but it was a quick switch.
Weird my zwave is already direct connect over 90% of devices and highest speed for all devices that support it.
What really happens is that no antenna causes a severe impedance mismatch, and all the power is reflected back to the transmitter output. Thatβs what causes the damage.
+1 Always power off the TX before changing an antenna.
SWR (reflected power) will go through the roof and potentially damage the RF output stage.
Wait....everyone doesn't just keep a finger on the SMA connector during swaps and use their body as an antenna?
I think you meant:
That sounds just a little pervy...
Finger, whole figure, whatever works....
