C7
Platform Version: 2.3.9.164
Z-Wave Version:
VersionReport(zWaveLibraryType:7, zWaveProtocolVersion:7, zWaveProtocolSubVersion:18, firmware0Version:7, firmware0SubVersion:18, hardwareVersion:1, firmwareTargets:1, targetVersions:[[target:1, version:7, subVersion:15]])
Powered by a PoE Splitter currently.
For the last few weeks (since the most recent selection of updates) I've been having terrible z-wave functionality... I, unfortunately, can't say what version started it... because I don't remember... but everything was working great, then I did an updated, stuff got kinda stupid, another update came out, so I did that. then I noticed that my z-wave radio firmware was out of date, so I updated that hoping to fix the issue... and a few more updates have come out, and I'm keeping on top of them... all of this to no avail...
What I'm seeing is devices commanded to do something, simply don't respond. the status doesn't updated, as if no command was given. If I go manually actuate the device, eventually the status might update in the hub.
I have tried shutting down the hub, pulling power for up to an hour, shutting off power to the entire house, for 30 min, nothing seems to help the issue. for about 10 min after the hub is booted I can control things seemingly fine, but then it all goes sideways.
I did happen to catch this in the z-wave logs today, almost like the radio just doesn't send the commands... but when it does, they go fine and the devices do what was commanded.
I have replaced the PoE Splitter, and I've tried powering it with a standard wall plug, doesn't seem to effect the outcome.
