I have a C7 that was working great for 2 years. I ended up doing a power cycle on it recently and it ended up with a corrupted database.
I've tried soft resets multiple times but when it reboots it gets stuck at Initializing Hub: 60% - starting UPNP . I also tried to reboot it into safe mode but that didn't work either.
I do have a hub protect subscription. Is there something I can do to get this working again, like a hard reset or would I be better to just migrate this to a new piece of hardware? I already pre-emptively bought a C8-pro in case that would work.
If you can get to the Diagnostics Menu (http://<HubIP>:8081) you could try dropping back to the previous firmware level, and then update to the current version after a successful boot.
I'm currently running 2.3.8.140 which is what the backups were done on. Is there a way to get back to that version of the firmware if I go back one version?
Then go to the diagnostic tool and click Restore Previous Version and you should see 2.2.8.140 available
- .140 was the last released iteration of the 2.3.8 platform version
Ok, I just went back to 2.3.8.138, Still had a corrupted DB afterwords and did a soft reset and am still in the same place as before. Would it be worth clicking the "clear past logs" on the soft reset menu or is that considered a bad idea?
Yup - about to suggest the same thing. Assuming you have a recent enough cloud backup that reset/restore isn't going to lose you a ton of devices/automation setups, etc., @lance.gleason that you've added since your most recent cloud backup.
He can't get his hub to fully boot up, so he can't do a cloud restore. He's already tried soft resets & safe mode...
So full reset via Diagnostic Tool was suggested to get the hub to boot fully up and then he could restore a cloud backup. But he can't reset as he has active subscriptions.
