C7 2.4.3.167 to 2.5.0.159 stuck at 25%
Platform Version2.4.3.167
Hardware VersionC-7
I tried to update from 2.4 to 2.5 and it got stuck at 25% for a couple of hours.
i logged into 8081 and did a soft reset and restore from backup. I’m back online and working, however when I did a search for this issue, i saw that bobby was able to do something via a private chat.
Any chance someone can help me out as well?
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
I discovered that going to the diag page and selecting "safe start" also gets things going. After my hub stalled I didn't reboot, just went into diag page and selected safe start, the hub came back with the newest version. I rebooted again normally and all was well.
is that the same as “safe mode” ?
well i’ll be…
thanks for the suggestion Rxich. that worked.
i’m on 2.5.0.159 after going to safe mode, then initiating a regular reboot.
Thanks for the help!
Yeah, same. Sorry with the terminology. Glad it worked for you !
FYI- This happened again, well because I’m old and I forget. Anywho, it was much worse with my C4 (Model T hub). I couldn’t even get into the diag page, hub was frozen with the 2.5.0.159 update at 30% for about 15 minutes. Diag page wouldn’t display even using several browsers, the ip for the diag page kept going back to the “update in progress” page stuck at 30%.
It was probably over 20 minutes before I could get to the diag page and reboot in safe mode. All is well now and time for a full backup.
