Unfortunately, I am still encountering the radio lock up issue during repair with 2.2.3.118 with firmware update. All devices were showing status "OK" before the repair started.
Once the busy messages start, the radio still responds to inbound packets with acks, but it appears to be completely unresponsive to upper layer requests. A reboot clears it.
The firmware has been updated. Attempting the update again produces a "Z-Wave Updater: Firmware is already up to date" message.
sys:12020-08-13 11:03:20.394 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:03:00.419 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:02:40.363 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:02:27.908 trace Z-Wave Node 4C: Repair is requesting device routeList
sys:12020-08-13 11:02:20.337 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:02:00.375 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:01:40.316 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:01:20.385 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:01:00.296 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:00:57.882 trace Z-Wave Node 4C: Repair is requesting device routeList
sys:12020-08-13 11:00:40.313 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:00:22.192 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:00:20.213 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:00:02.153 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 11:00:00.052 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:59:42.074 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:59:27.854 trace Z-Wave Node 4C: Repair is requesting device routeList
sys:12020-08-13 10:59:22.054 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:59:02.051 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:58:42.002 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:58:21.979 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:58:02.007 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:57:57.851 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:57:57.840 trace Z-Wave Node 4C: Repair is updating neighbors
sys:12020-08-13 10:57:41.959 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:57:21.918 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:57:01.902 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:56:41.844 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:56:27.822 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:56:27.809 trace Z-Wave Node 4C: Repair is updating neighbors
sys:12020-08-13 10:56:21.924 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:56:01.962 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:55:41.937 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:55:21.859 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:55:01.850 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:54:57.802 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:54:57.785 trace Z-Wave Node 4C: Repair is updating neighbors
sys:12020-08-13 10:54:41.779 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:54:21.756 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:54:01.692 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:53:41.673 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:53:27.773 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:53:27.764 trace Z-Wave Node 4C: Repair is updating neighbors
sys:12020-08-13 10:53:27.753 trace Z-Wave Node 4C: Repair starting
sys:12020-08-13 10:53:21.646 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:53:01.698 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:52:41.606 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:52:21.591 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:52:01.600 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:51:57.730 error Z-Wave Node 4B: Repair failed, the maximum retries have been exceeded
sys:12020-08-13 10:51:41.555 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:51:21.543 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:51:01.517 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:50:41.528 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:50:27.695 trace Z-Wave Node 4B: Repair is requesting device routeList
sys:12020-08-13 10:50:21.459 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:50:01.407 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:49:41.387 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:49:21.426 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:49:01.480 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:48:57.691 trace Z-Wave Node 4B: Repair is requesting device routeList
sys:12020-08-13 10:48:41.339 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:48:21.321 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:48:01.304 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:47:41.304 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:47:27.667 trace Z-Wave Node 4B: Repair is requesting device routeList
sys:12020-08-13 10:47:21.279 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:47:01.267 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:46:41.232 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:46:21.299 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:46:01.230 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:45:57.642 trace Z-Wave Node 4B: Repair is requesting device routeList
sys:12020-08-13 10:45:41.219 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:45:21.212 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:45:01.165 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:44:41.126 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:44:27.619 trace Z-Wave Node 4B: Repair is requesting device routeList
sys:12020-08-13 10:44:21.095 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:44:01.112 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:43:41.052 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:43:21.061 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:43:01.106 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:42:57.602 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:42:57.590 trace Z-Wave Node 4B: Repair is updating neighbors
sys:12020-08-13 10:42:40.995 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:42:20.951 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:42:00.920 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:41:40.891 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:41:27.577 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:41:27.565 trace Z-Wave Node 4B: Repair is updating neighbors
sys:12020-08-13 10:41:20.902 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:41:00.897 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:40:40.877 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:40:20.861 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:40:00.966 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:39:57.557 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:39:57.541 trace Z-Wave Node 4B: Repair is updating neighbors
sys:12020-08-13 10:39:40.859 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:39:20.765 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:39:00.781 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:38:40.818 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:38:27.537 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:38:27.533 trace Z-Wave Node 4B: Repair is updating neighbors
sys:12020-08-13 10:38:27.517 trace Z-Wave Node 4B: Repair starting
sys:12020-08-13 10:38:20.779 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:38:00.700 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:37:40.707 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:37:20.680 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:37:00.700 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:36:57.488 error Z-Wave Node 4A: Repair failed, the maximum retries have been exceeded
sys:12020-08-13 10:36:40.659 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:36:20.632 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:36:00.666 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:35:40.621 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:35:27.480 trace Z-Wave Node 4A: Repair is requesting device routeList
sys:12020-08-13 10:35:20.591 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:35:00.551 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:34:40.506 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:34:20.476 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:34:00.466 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:33:57.456 trace Z-Wave Node 4A: Repair is requesting device routeList
sys:12020-08-13 10:33:40.430 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:33:20.397 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:33:00.402 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:32:40.385 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:32:27.435 trace Z-Wave Node 4A: Repair is requesting device routeList
sys:12020-08-13 10:32:20.354 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:32:00.389 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:31:40.322 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:31:20.393 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:31:00.299 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:30:57.412 trace Z-Wave Node 4A: Repair is requesting device routeList
sys:12020-08-13 10:30:40.262 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:30:20.213 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:30:00.056 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:29:27.386 trace Z-Wave Node 4A: Repair is requesting device routeList
sys:12020-08-13 10:27:57.350 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:27:57.337 trace Z-Wave Node 4A: Repair is updating neighbors
sys:12020-08-13 10:27:23.818 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:27:03.796 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:26:43.773 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:26:27.331 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:26:27.316 trace Z-Wave Node 4A: Repair is updating neighbors
sys:12020-08-13 10:26:23.790 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:26:03.781 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:25:43.736 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:25:23.709 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:25:03.701 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:24:57.293 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:24:57.274 trace Z-Wave Node 4A: Repair is updating neighbors
sys:12020-08-13 10:24:43.692 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:24:23.661 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:24:03.645 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:23:43.597 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:23:27.253 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:23:27.249 trace Z-Wave Node 4A: Repair is updating neighbors
sys:12020-08-13 10:23:27.242 trace Z-Wave Node 4A: Repair starting
sys:12020-08-13 10:23:23.653 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:23:03.615 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:22:43.580 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:22:23.574 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:22:03.579 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:21:57.212 error Z-Wave Node 49: Repair failed, the maximum retries have been exceeded
sys:12020-08-13 10:21:43.485 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:21:23.484 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:21:03.426 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:20:43.405 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:20:27.195 trace Z-Wave Node 49: Repair is requesting device routeList
sys:12020-08-13 10:20:23.492 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:20:03.368 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:19:43.338 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:19:23.314 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:19:03.336 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:18:57.192 trace Z-Wave Node 49: Repair is requesting device routeList
sys:12020-08-13 10:18:43.306 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:18:23.275 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:18:03.239 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:17:43.277 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:17:27.167 trace Z-Wave Node 49: Repair is requesting device routeList
sys:12020-08-13 10:17:23.249 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:17:03.144 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:16:43.140 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:16:23.178 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:16:03.238 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:15:57.146 trace Z-Wave Node 49: Repair is requesting device routeList
sys:12020-08-13 10:15:43.087 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:15:23.069 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:15:03.058 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:14:43.030 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:14:27.122 trace Z-Wave Node 49: Repair is requesting device routeList
sys:12020-08-13 10:14:23.015 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:14:02.999 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:13:42.987 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:13:23.062 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:13:02.963 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:12:57.108 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:12:57.096 trace Z-Wave Node 49: Repair is updating neighbors
sys:12020-08-13 10:12:42.962 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:12:22.947 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:12:02.905 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:11:42.782 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:11:27.090 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:11:27.072 trace Z-Wave Node 49: Repair is updating neighbors
sys:12020-08-13 10:11:22.759 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:11:02.763 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:10:42.699 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:10:22.706 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:10:02.718 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:09:57.067 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:09:57.051 trace Z-Wave Node 49: Repair is updating neighbors
sys:12020-08-13 10:09:42.644 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:09:22.607 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:09:02.577 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:08:42.552 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:08:27.028 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:08:27.023 trace Z-Wave Node 49: Repair is updating neighbors
sys:12020-08-13 10:08:27.016 trace Z-Wave Node 49: Repair starting
sys:12020-08-13 10:08:22.561 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:08:02.532 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:07:42.508 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:07:22.475 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:07:02.532 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:06:56.989 error Z-Wave Node 48: Repair failed, the maximum retries have been exceeded
sys:12020-08-13 10:06:42.460 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:06:22.390 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:06:02.418 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:05:42.420 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:05:26.953 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:05:26.936 trace Z-Wave Node 48: Repair is deleting routes
sys:12020-08-13 10:05:22.383 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:05:02.312 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:04:42.297 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:04:22.287 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:04:02.304 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:03:56.936 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:03:56.919 trace Z-Wave Node 48: Repair is deleting routes
sys:12020-08-13 10:03:42.280 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:03:22.248 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:03:02.287 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:02:42.258 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:02:26.912 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:02:26.897 trace Z-Wave Node 48: Repair is deleting routes
sys:12020-08-13 10:02:22.307 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:02:02.185 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:01:42.153 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:01:22.129 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:01:12.099 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:01:02.091 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:00:54.269 trace Z-Wave Node 48: Repair is deleting routes
sys:12020-08-13 10:00:53.949 trace Z-Wave Node 48: Repair is requesting device routeList
sys:12020-08-13 10:00:52.082 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:00:42.180 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:00:32.193 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:00:31.869 trace Z-Wave Node 48: Repair is updating neighbors
sys:12020-08-13 10:00:31.865 trace Z-Wave Node 48: Repair starting
sys:12020-08-13 10:00:27.495 trace Z-Wave Node 47: Repair is done.
sys:12020-08-13 10:00:27.492 trace Z-Wave Node 47: Repair is adding return routes
sys:12020-08-13 10:00:27.115 trace Z-Wave Node 47: Repair is deleting routes
sys:12020-08-13 10:00:26.332 trace Z-Wave Node 47: Repair is requesting device routeList
sys:12020-08-13 10:00:20.326 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 10:00:06.862 trace Z-Wave Node 47: Repair is updating neighbors
sys:12020-08-13 10:00:06.855 trace Z-Wave Node 47: Repair starting
sys:12020-08-13 10:00:00.242 trace Z-Wave Node 3F: Repair is done.
sys:12020-08-13 10:00:00.239 trace Z-Wave Node 3F: Repair is adding return routes
sys:12020-08-13 10:00:00.096 warn Z-Wave Network responded with Busy message.
sys:12020-08-13 09:59:59.182 trace Z-Wave Node 3F: Repair is deleting routes
sys:12020-08-13 09:59:58.825 trace Z-Wave Node 3F: Repair is requesting device routeList
sys:12020-08-13 09:59:46.839 trace Z-Wave Node 3F: Repair is updating neighbors
sys:12020-08-13 09:59:46.832 trace Z-Wave Node 3F: Repair starting
sys:12020-08-13 09:59:39.606 trace Z-Wave Node 3E: Repair is done.
sys:12020-08-13 09:59:39.601 trace Z-Wave Node 3E: Repair is adding return routes
sys:12020-08-13 09:59:38.551 trace Z-Wave Node 3E: Repair is deleting routes
sys:12020-08-13 09:59:38.187 trace Z-Wave Node 3E: Repair is requesting device routeList
sys:12020-08-13 09:59:26.827 trace Z-Wave Node 3E: Repair is updating neighbors
sys:12020-08-13 09:59:26.813 trace Z-Wave Node 3E: Repair starting
sys:12020-08-13 09:59:18.825 trace Z-Wave Node 3D: Repair is done.
sys:12020-08-13 09:59:18.816 trace Z-Wave Node 3D: Repair is adding return routes
sys:12020-08-13 09:59:17.617 trace Z-Wave Node 3D: Repair is deleting routes
sys:12020-08-13 09:59:17.243 trace Z-Wave Node 3D: Repair is requesting device routeList
sys:12020-08-13 09:59:06.796 trace Z-Wave Node 3D: Repair is updating neighbors
sys:12020-08-13 09:59:06.786 trace Z-Wave Node 3D: Repair starting
sys:12020-08-13 09:58:58.193 trace Z-Wave Node 3C: Repair is done.
sys:12020-08-13 09:58:58.184 trace Z-Wave Node 3C: Repair is adding return routes
sys:12020-08-13 09:58:55.704 trace Z-Wave Node 3C: Repair is deleting routes
sys:12020-08-13 09:58:54.854 trace Z-Wave Node 3C: Repair is requesting device routeList
sys:12020-08-13 09:58:41.792 trace Z-Wave Node 3C: Repair is updating neighbors
sys:12020-08-13 09:58:41.774 trace Z-Wave Node 3C: Repair starting
sys:12020-08-13 09:58:37.358 trace Z-Wave Node 3B: Repair is done.
sys:12020-08-13 09:58:37.348 trace Z-Wave Node 3B: Repair is adding return routes
sys:12020-08-13 09:58:36.365 trace Z-Wave Node 3B: Repair is deleting routes
sys:12020-08-13 09:58:35.942 trace Z-Wave Node 3B: Repair is requesting device routeList
sys:12020-08-13 09:58:16.757 trace Z-Wave Node 3B: Repair is updating neighbors
sys:12020-08-13 09:56:46.736 trace Z-Wave Node 3B: Repair is updating neighbors
sys:12020-08-13 09:56:46.724 trace Z-Wave Node 3B: Repair starting
sys:12020-08-13 09:56:42.248 trace Z-Wave Node 3A: Repair is done.
sys:12020-08-13 09:56:42.244 trace Z-Wave Node 3A: Repair is adding return routes
sys:12020-08-13 09:56:41.570 trace Z-Wave Node 3A: Repair is deleting routes
sys:12020-08-13 09:56:41.494 trace Z-Wave Node 3A: Repair is requesting device routeList
sys:12020-08-13 09:56:31.715 trace Z-Wave Node 3A: Repair is updating neighbors
sys:12020-08-13 09:56:31.704 trace Z-Wave Node 3A: Repair starting
sys:12020-08-13 09:56:26.722 trace Z-Wave Node 39: Repair is done.
sys:12020-08-13 09:56:26.718 trace Z-Wave Node 39: Repair is adding return routes
sys:12020-08-13 09:56:26.117 trace Z-Wave Node 39: Repair is deleting routes
sys:12020-08-13 09:56:26.053 trace Z-Wave Node 39: Repair is requesting device routeList
sys:12020-08-13 09:56:16.687 trace Z-Wave Node 39: Repair is updating neighbors
sys:12020-08-13 09:56:16.683 trace Z-Wave Node 39: Repair starting
sys:12020-08-13 09:56:10.702 trace Z-Wave Node 38: Repair is done.
sys:12020-08-13 09:56:10.699 trace Z-Wave Node 38: Repair is adding return routes
sys:12020-08-13 09:56:09.550 trace Z-Wave Node 38: Repair is deleting routes
sys:12020-08-13 09:56:09.485 trace Z-Wave Node 38: Repair is requesting device routeList
sys:12020-08-13 09:56:01.697 trace Z-Wave Node 38: Repair is updating neighbors
sys:12020-08-13 09:56:01.678 trace Z-Wave Node 38: Repair starting
sys:12020-08-13 09:55:55.954 trace Z-Wave Node 37: Repair is done.
sys:12020-08-13 09:55:55.950 trace Z-Wave Node 37: Repair is adding return routes
sys:12020-08-13 09:55:55.016 trace Z-Wave Node 37: Repair is deleting routes
sys:12020-08-13 09:55:54.953 trace Z-Wave Node 37: Repair is requesting device routeList
sys:12020-08-13 09:55:46.660 trace Z-Wave Node 37: Repair is updating neighbors
sys:12020-08-13 09:54:16.636 trace Z-Wave Node 37: Repair is updating neighbors
sys:12020-08-13 09:54:16.630 trace Z-Wave Node 37: Repair starting
sys:12020-08-13 09:54:10.798 trace Z-Wave Node 36: Repair is done.
sys:12020-08-13 09:54:10.788 trace Z-Wave Node 36: Repair is adding return routes
sys:12020-08-13 09:54:10.022 trace Z-Wave Node 36: Repair is deleting routes
sys:12020-08-13 09:54:09.959 trace Z-Wave Node 36: Repair is requesting device routeList
sys:12020-08-13 09:54:01.615 trace Z-Wave Node 36: Repair is updating neighbors
sys:12020-08-13 09:54:01.609 trace Z-Wave Node 36: Repair starting
sys:12020-08-13 09:53:57.287 trace Z-Wave Node 35: Repair is done.
sys:12020-08-13 09:53:57.277 trace Z-Wave Node 35: Repair is adding return routes
sys:12020-08-13 09:53:55.751 trace Z-Wave Node 35: Repair is deleting routes
sys:12020-08-13 09:53:55.370 trace Z-Wave Node 35: Repair is requesting device routeList
sys:12020-08-13 09:53:46.598 trace Z-Wave Node 35: Repair is updating neighbors
sys:12020-08-13 09:53:46.586 trace Z-Wave Node 35: Repair starting
sys:12020-08-13 09:53:42.394 trace Z-Wave Node 34: Repair is done.
sys:12020-08-13 09:53:42.389 trace Z-Wave Node 34: Repair is adding return routes
sys:12020-08-13 09:53:41.146 trace Z-Wave Node 34: Repair is deleting routes
sys:12020-08-13 09:53:40.822 trace Z-Wave Node 34: Repair is requesting device routeList
sys:12020-08-13 09:53:31.567 trace Z-Wave Node 34: Repair is updating neighbors
sys:12020-08-13 09:52:01.556 trace Z-Wave Node 34: Repair is updating neighbors
sys:12020-08-13 09:52:01.553 trace Z-Wave Node 34: Repair starting
sys:12020-08-13 09:51:56.723 trace Z-Wave Node 33: Repair is done.
sys:12020-08-13 09:51:56.713 trace Z-Wave Node 33: Repair is adding return routes
sys:12020-08-13 09:51:36.777 trace Z-Wave Node 33: Repair is deleting routes
sys:12020-08-13 09:51:36.386 trace Z-Wave Node 33: Repair is requesting device routeList
sys:12020-08-13 09:51:26.550 trace Z-Wave Node 33: Repair is updating neighbors
sys:12020-08-13 09:51:26.547 trace Z-Wave Node 33: Repair starting
sys:12020-08-13 09:51:18.198 trace Z-Wave Node 32: Repair is done.
sys:12020-08-13 09:51:18.188 trace Z-Wave Node 32: Repair is adding return routes
sys:12020-08-13 09:51:17.002 trace Z-Wave Node 32: Repair is deleting routes
sys:12020-08-13 09:51:16.578 trace Z-Wave Node 32: Repair is requesting device routeList
sys:12020-08-13 09:51:06.547 trace Z-Wave Node 32: Repair is updating neighbors
sys:12020-08-13 09:51:06.541 trace Z-Wave Node 32: Repair starting
sys:12020-08-13 09:50:57.719 trace Z-Wave Node 31: Repair is done.
sys:12020-08-13 09:50:57.709 trace Z-Wave Node 31: Repair is adding return routes
sys:12020-08-13 09:50:56.298 trace Z-Wave Node 31: Repair is deleting routes
sys:12020-08-13 09:50:55.904 trace Z-Wave Node 31: Repair is requesting device routeList
sys:12020-08-13 09:50:46.521 trace Z-Wave Node 31: Repair is updating neighbors
sys:12020-08-13 09:50:46.515 trace Z-Wave Node 31: Repair starting
sys:12020-08-13 09:50:41.777 trace Z-Wave Node 30: Repair is done.
sys:12020-08-13 09:50:41.769 trace Z-Wave Node 30: Repair is adding return routes
sys:12020-08-13 09:50:39.654 trace Z-Wave Node 30: Repair is deleting routes
sys:12020-08-13 09:50:38.788 trace Z-Wave Node 30: Repair is requesting device routeList
sys:12020-08-13 09:50:26.499 trace Z-Wave Node 30: Repair is updating neighbors
sys:12020-08-13 09:50:26.491 trace Z-Wave Node 30: Repair starting
sys:12020-08-13 09:50:18.452 trace Z-Wave Node 2F: Repair is done.
sys:12020-08-13 09:50:18.440 trace Z-Wave Node 2F: Repair is adding return routes
sys:12020-08-13 09:50:16.955 trace Z-Wave Node 2F: Repair is deleting routes
sys:12020-08-13 09:50:16.585 trace Z-Wave Node 2F: Repair is requesting device routeList
sys:12020-08-13 09:50:06.478 trace Z-Wave Node 2F: Repair is updating neighbors
sys:12020-08-13 09:50:06.472 trace Z-Wave Node 2F: Repair starting
sys:12020-08-13 09:49:59.049 trace Z-Wave Node 2E: Repair is done.
sys:12020-08-13 09:49:59.045 trace Z-Wave Node 2E: Repair is adding return routes
sys:12020-08-13 09:49:56.422 trace Z-Wave Node 2E: Repair is deleting routes
sys:12020-08-13 09:49:55.985 trace Z-Wave Node 2E: Repair is requesting device routeList
sys:12020-08-13 09:49:46.456 trace Z-Wave Node 2E: Repair is updating neighbors
sys:12020-08-13 09:49:46.441 trace Z-Wave Node 2E: Repair starting
sys:12020-08-13 09:49:39.936 trace Z-Wave Node 2C: Repair is done.
sys:12020-08-13 09:49:39.926 trace Z-Wave Node 2C: Repair is adding return routes
sys:12020-08-13 09:49:38.785 trace Z-Wave Node 2C: Repair is deleting routes
sys:12020-08-13 09:49:38.107 trace Z-Wave Node 2C: Repair is requesting device routeList
sys:12020-08-13 09:49:26.433 trace Z-Wave Node 2C: Repair is updating neighbors
sys:12020-08-13 09:49:26.417 trace Z-Wave Node 2C: Repair starting
sys:12020-08-13 09:49:17.466 trace Z-Wave Node 2B: Repair is done.
sys:12020-08-13 09:49:17.455 trace Z-Wave Node 2B: Repair is adding return routes
sys:12020-08-13 09:49:16.078 trace Z-Wave Node 2B: Repair is deleting routes
sys:12020-08-13 09:49:15.646 trace Z-Wave Node 2B: Repair is requesting device routeList
sys:12020-08-13 09:49:01.398 trace Z-Wave Node 2B: Repair is updating neighbors
sys:12020-08-13 09:49:01.394 trace Z-Wave Node 2B: Repair starting
sys:12020-08-13 09:48:52.784 trace Z-Wave Node 2A: Repair is done.
sys:12020-08-13 09:48:52.773 trace Z-Wave Node 2A: Repair is adding return routes
sys:12020-08-13 09:48:50.554 trace Z-Wave Node 2A: Repair is deleting routes
sys:12020-08-13 09:48:49.856 trace Z-Wave Node 2A: Repair is requesting device routeList
sys:12020-08-13 09:48:36.379 trace Z-Wave Node 2A: Repair is updating neighbors
sys:12020-08-13 09:48:36.366 trace Z-Wave Node 2A: Repair starting
sys:12020-08-13 09:48:30.985 trace Z-Wave Node 29: Repair is done.
sys:12020-08-13 09:48:30.981 trace Z-Wave Node 29: Repair is adding return routes
sys:12020-08-13 09:48:28.370 trace Z-Wave Node 29: Repair is deleting routes
sys:12020-08-13 09:48:27.854 trace Z-Wave Node 29: Repair is requesting device routeList
sys:12020-08-13 09:48:16.356 trace Z-Wave Node 29: Repair is updating neighbors
sys:12020-08-13 09:48:16.342 trace Z-Wave Node 29: Repair starting
sys:12020-08-13 09:48:09.335 trace Z-Wave Node 28: Repair is done.
sys:12020-08-13 09:48:09.325 trace Z-Wave Node 28: Repair is adding return routes
sys:12020-08-13 09:48:07.670 trace Z-Wave Node 28: Repair is deleting routes
sys:12020-08-13 09:48:07.290 trace Z-Wave Node 28: Repair is requesting device routeList
sys:12020-08-13 09:47:56.323 trace Z-Wave Node 28: Repair is updating neighbors
sys:12020-08-13 09:47:56.320 trace Z-Wave Node 28: Repair starting
sys:12020-08-13 09:47:48.586 trace Z-Wave Node 27: Repair is done.
sys:12020-08-13 09:47:48.576 trace Z-Wave Node 27: Repair is adding return routes
sys:12020-08-13 09:47:47.354 trace Z-Wave Node 27: Repair is deleting routes
sys:12020-08-13 09:47:46.868 trace Z-Wave Node 27: Repair is requesting device routeList
sys:12020-08-13 09:47:36.326 trace Z-Wave Node 27: Repair is updating neighbors
sys:12020-08-13 09:47:36.316 trace Z-Wave Node 27: Repair starting
sys:12020-08-13 09:47:28.408 trace Z-Wave Node 26: Repair is done.
sys:12020-08-13 09:47:28.404 trace Z-Wave Node 26: Repair is adding return routes
sys:12020-08-13 09:47:27.302 trace Z-Wave Node 26: Repair is deleting routes
sys:12020-08-13 09:47:26.982 trace Z-Wave Node 26: Repair is requesting device routeList
sys:12020-08-13 09:47:16.309 trace Z-Wave Node 26: Repair is updating neighbors
sys:12020-08-13 09:47:16.296 trace Z-Wave Node 26: Repair starting
sys:12020-08-13 09:47:11.075 trace Z-Wave Node 25: Repair is done.
sys:12020-08-13 09:47:11.065 trace Z-Wave Node 25: Repair is adding return routes
sys:12020-08-13 09:47:09.389 trace Z-Wave Node 25: Repair is deleting routes
sys:12020-08-13 09:47:08.469 trace Z-Wave Node 25: Repair is requesting device routeList
sys:12020-08-13 09:46:56.279 trace Z-Wave Node 25: Repair is updating neighbors
sys:12020-08-13 09:46:56.274 trace Z-Wave Node 25: Repair starting
sys:12020-08-13 09:46:50.333 trace Z-Wave Node 24: Repair is done.
sys:12020-08-13 09:46:50.321 trace Z-Wave Node 24: Repair is adding return routes
sys:12020-08-13 09:46:49.268 trace Z-Wave Node 24: Repair is deleting routes
sys:12020-08-13 09:46:49.199 trace Z-Wave Node 24: Repair is requesting device routeList
sys:12020-08-13 09:46:41.258 trace Z-Wave Node 24: Repair is updating neighbors
sys:12020-08-13 09:46:41.248 trace Z-Wave Node 24: Repair starting
sys:12020-08-13 09:46:37.175 trace Z-Wave Node 22: Repair is done.
sys:12020-08-13 09:46:37.165 trace Z-Wave Node 22: Repair is adding return routes
sys:12020-08-13 09:46:36.126 trace Z-Wave Node 22: Repair is deleting routes
sys:12020-08-13 09:46:35.737 trace Z-Wave Node 22: Repair is requesting device routeList
sys:12020-08-13 09:46:26.240 trace Z-Wave Node 22: Repair is updating neighbors
sys:12020-08-13 09:46:26.230 trace Z-Wave Node 22: Repair starting
sys:12020-08-13 09:46:17.944 trace Z-Wave Node 21: Repair is done.
sys:12020-08-13 09:46:17.934 trace Z-Wave Node 21: Repair is adding return routes
sys:12020-08-13 09:46:16.920 trace Z-Wave Node 21: Repair is deleting routes
sys:12020-08-13 09:46:15.166 trace Z-Wave Node 21: Repair is requesting device routeList
sys:12020-08-13 09:46:01.214 trace Z-Wave Node 21: Repair is updating neighbors
sys:12020-08-13 09:46:01.207 trace Z-Wave Node 21: Repair starting
sys:12020-08-13 09:45:54.523 trace Z-Wave Node 1F: Repair is done.
sys:12020-08-13 09:45:54.519 trace Z-Wave Node 1F: Repair is adding return routes
sys:12020-08-13 09:45:52.799 trace Z-Wave Node 1F: Repair is deleting routes
sys:12020-08-13 09:45:52.458 trace Z-Wave Node 1F: Repair is requesting device routeList
sys:12020-08-13 09:45:41.189 trace Z-Wave Node 1F: Repair is updating neighbors
sys:12020-08-13 09:45:41.186 trace Z-Wave Node 1F: Repair starting
sys:12020-08-13 09:45:36.269 trace Z-Wave Node 1E: Repair is done.
sys:12020-08-13 09:45:36.258 trace Z-Wave Node 1E: Repair is adding return routes
sys:12020-08-13 09:45:35.083 trace Z-Wave Node 1E: Repair is deleting routes
sys:12020-08-13 09:45:34.703 trace Z-Wave Node 1E: Repair is requesting device routeList
sys:12020-08-13 09:45:26.198 trace Z-Wave Node 1E: Repair is updating neighbors
sys:12020-08-13 09:45:26.181 trace Z-Wave Node 1E: Repair starting
sys:12020-08-13 09:45:21.627 trace Z-Wave Node 1D: Repair is done.
sys:12020-08-13 09:45:21.617 trace Z-Wave Node 1D: Repair is adding return routes
sys:12020-08-13 09:45:20.827 trace Z-Wave Node 1D: Repair is deleting routes
sys:12020-08-13 09:45:20.153 trace Z-Wave Node 1D: Repair is requesting device routeList
sys:12020-08-13 09:45:11.166 trace Z-Wave Node 1D: Repair is updating neighbors
sys:12020-08-13 09:45:11.159 trace Z-Wave Node 1D: Repair starting
sys:12020-08-13 09:45:04.866 trace Z-Wave Node 1C: Repair is done.
sys:12020-08-13 09:45:04.857 trace Z-Wave Node 1C: Repair is adding return routes
sys:12020-08-13 09:45:02.952 trace Z-Wave Node 1C: Repair is deleting routes
sys:12020-08-13 09:45:01.906 trace Z-Wave Node 1C: Repair is requesting device routeList
sys:12020-08-13 09:44:51.143 trace Z-Wave Node 1C: Repair is updating neighbors
sys:12020-08-13 09:44:51.137 trace Z-Wave Node 1C: Repair starting
sys:12020-08-13 09:44:43.126 trace Z-Wave Node 1B: Repair is done.
sys:12020-08-13 09:44:43.122 trace Z-Wave Node 1B: Repair is adding return routes
sys:12020-08-13 09:44:41.896 trace Z-Wave Node 1B: Repair is deleting routes
sys:12020-08-13 09:44:41.514 trace Z-Wave Node 1B: Repair is requesting device routeList
sys:12020-08-13 09:44:31.125 trace Z-Wave Node 1B: Repair is updating neighbors
sys:12020-08-13 09:44:31.115 trace Z-Wave Node 1B: Repair starting
sys:12020-08-13 09:44:23.718 trace Z-Wave Node 1A: Repair is done.
sys:12020-08-13 09:44:23.708 trace Z-Wave Node 1A: Repair is adding return routes
sys:12020-08-13 09:44:21.713 trace Z-Wave Node 1A: Repair is deleting routes
sys:12020-08-13 09:44:21.365 trace Z-Wave Node 1A: Repair is requesting device routeList
sys:12020-08-13 09:44:11.104 trace Z-Wave Node 1A: Repair is updating neighbors
sys:12020-08-13 09:42:41.083 trace Z-Wave Node 1A: Repair is updating neighbors
sys:12020-08-13 09:42:41.064 trace Z-Wave Node 1A: Repair starting
sys:12020-08-13 09:42:32.361 trace Z-Wave Node 19: Repair is done.
sys:12020-08-13 09:42:32.357 trace Z-Wave Node 19: Repair is adding return routes
sys:12020-08-13 09:42:31.198 trace Z-Wave Node 19: Repair is deleting routes
sys:12020-08-13 09:42:30.833 trace Z-Wave Node 19: Repair is requesting device routeList
sys:12020-08-13 09:42:21.061 trace Z-Wave Node 19: Repair is updating neighbors
sys:12020-08-13 09:42:21.042 trace Z-Wave Node 19: Repair starting
sys:12020-08-13 09:42:15.372 trace Z-Wave Node 18: Repair is done.
sys:12020-08-13 09:42:15.368 trace Z-Wave Node 18: Repair is adding return routes
sys:12020-08-13 09:42:13.378 trace Z-Wave Node 18: Repair is deleting routes
sys:12020-08-13 09:42:12.513 trace Z-Wave Node 18: Repair is requesting device routeList
sys:12020-08-13 09:42:01.027 trace Z-Wave Node 18: Repair is updating neighbors
sys:12020-08-13 09:42:01.020 trace Z-Wave Node 18: Repair starting
sys:12020-08-13 09:41:52.722 trace Z-Wave Node 17: Repair is done.
sys:12020-08-13 09:41:52.717 trace Z-Wave Node 17: Repair is adding return routes
sys:12020-08-13 09:41:51.315 trace Z-Wave Node 17: Repair is deleting routes
sys:12020-08-13 09:41:50.936 trace Z-Wave Node 17: Repair is requesting device routeList
sys:12020-08-13 09:41:41.014 trace Z-Wave Node 17: Repair is updating neighbors
sys:12020-08-13 09:41:40.998 trace Z-Wave Node 17: Repair starting
sys:12020-08-13 09:41:34.080 trace Z-Wave Node 16: Repair is done.
sys:12020-08-13 09:41:34.072 trace Z-Wave Node 16: Repair is adding return routes
sys:12020-08-13 09:41:33.130 trace Z-Wave Node 16: Repair is deleting routes
sys:12020-08-13 09:41:33.061 trace Z-Wave Node 16: Repair is requesting device routeList
sys:12020-08-13 09:41:25.983 trace Z-Wave Node 16: Repair is updating neighbors
sys:12020-08-13 09:41:25.976 trace Z-Wave Node 16: Repair starting
sys:12020-08-13 09:41:19.256 trace Z-Wave Node 15: Repair is done.
sys:12020-08-13 09:41:19.246 trace Z-Wave Node 15: Repair is adding return routes
sys:12020-08-13 09:41:18.358 trace Z-Wave Node 15: Repair is deleting routes
sys:12020-08-13 09:41:18.290 trace Z-Wave Node 15: Repair is requesting device routeList
sys:12020-08-13 09:41:10.969 trace Z-Wave Node 15: Repair is updating neighbors
sys:12020-08-13 09:41:10.955 trace Z-Wave Node 15: Repair starting
sys:12020-08-13 09:41:05.897 trace Z-Wave Node 14: Repair is done.
sys:12020-08-13 09:41:05.893 trace Z-Wave Node 14: Repair is adding return routes
sys:12020-08-13 09:41:04.985 trace Z-Wave Node 14: Repair is deleting routes
sys:12020-08-13 09:41:04.901 trace Z-Wave Node 14: Repair is requesting device routeList
sys:12020-08-13 09:40:55.938 trace Z-Wave Node 14: Repair is updating neighbors
sys:12020-08-13 09:40:55.934 trace Z-Wave Node 14: Repair starting
sys:12020-08-13 09:40:47.415 trace Z-Wave Node 13: Repair is done.
sys:12020-08-13 09:40:47.405 trace Z-Wave Node 13: Repair is adding return routes
sys:12020-08-13 09:40:45.702 trace Z-Wave Node 13: Repair is deleting routes
sys:12020-08-13 09:40:45.261 trace Z-Wave Node 13: Repair is requesting device routeList
sys:12020-08-13 09:40:35.947 trace Z-Wave Node 13: Repair is updating neighbors
sys:12020-08-13 09:40:35.929 trace Z-Wave Node 13: Repair starting
sys:12020-08-13 09:40:30.308 trace Z-Wave Node 12: Repair is done.
sys:12020-08-13 09:40:30.298 trace Z-Wave Node 12: Repair is adding return routes
sys:12020-08-13 09:40:28.258 trace Z-Wave Node 12: Repair is deleting routes
sys:12020-08-13 09:40:27.402 trace Z-Wave Node 12: Repair is requesting device routeList
sys:12020-08-13 09:40:15.929 trace Z-Wave Node 12: Repair is updating neighbors
sys:12020-08-13 09:40:15.907 trace Z-Wave Node 12: Repair starting
sys:12020-08-13 09:40:07.289 trace Z-Wave Node 11: Repair is done.
sys:12020-08-13 09:40:07.282 trace Z-Wave Node 11: Repair is adding return routes
sys:12020-08-13 09:40:05.956 trace Z-Wave Node 11: Repair is deleting routes
sys:12020-08-13 09:40:05.294 trace Z-Wave Node 11: Repair is requesting device routeList
sys:12020-08-13 09:39:55.898 trace Z-Wave Node 11: Repair is updating neighbors
sys:12020-08-13 09:39:55.885 trace Z-Wave Node 11: Repair starting
sys:12020-08-13 09:39:48.149 trace Z-Wave Node 10: Repair is done.
sys:12020-08-13 09:39:48.145 trace Z-Wave Node 10: Repair is adding return routes
sys:12020-08-13 09:39:46.545 trace Z-Wave Node 10: Repair is deleting routes
sys:12020-08-13 09:39:46.193 trace Z-Wave Node 10: Repair is requesting device routeList
sys:12020-08-13 09:39:35.869 trace Z-Wave Node 10: Repair is updating neighbors
sys:12020-08-13 09:39:35.862 trace Z-Wave Node 10: Repair starting
sys:12020-08-13 09:39:27.725 trace Z-Wave Node 0F: Repair is done.
sys:12020-08-13 09:39:27.715 trace Z-Wave Node 0F: Repair is adding return routes
sys:12020-08-13 09:39:26.204 trace Z-Wave Node 0F: Repair is deleting routes
sys:12020-08-13 09:39:25.895 trace Z-Wave Node 0F: Repair is requesting device routeList
sys:12020-08-13 09:39:15.846 trace Z-Wave Node 0F: Repair is updating neighbors
sys:12020-08-13 09:39:15.839 trace Z-Wave Node 0F: Repair starting
sys:12020-08-13 09:39:11.228 trace Z-Wave Node 0E: Repair is done.
sys:12020-08-13 09:39:11.217 trace Z-Wave Node 0E: Repair is adding return routes
sys:12020-08-13 09:39:06.513 trace Z-Wave Node 0E: Repair is deleting routes
sys:12020-08-13 09:39:06.121 trace Z-Wave Node 0E: Repair is requesting device routeList
sys:12020-08-13 09:38:55.832 trace Z-Wave Node 0E: Repair is updating neighbors
sys:12020-08-13 09:38:55.817 trace Z-Wave Node 0E: Repair starting
sys:12020-08-13 09:38:49.834 trace Z-Wave Node 0D: Repair is done.
sys:12020-08-13 09:38:49.830 trace Z-Wave Node 0D: Repair is adding return routes
sys:12020-08-13 09:38:48.940 trace Z-Wave Node 0D: Repair is deleting routes
sys:12020-08-13 09:38:48.855 trace Z-Wave Node 0D: Repair is requesting device routeList
sys:12020-08-13 09:38:40.802 trace Z-Wave Node 0D: Repair is updating neighbors
sys:12020-08-13 09:38:40.798 trace Z-Wave Node 0D: Repair starting
sys:12020-08-13 09:38:33.857 trace Z-Wave Node 0C: Repair is done.
sys:12020-08-13 09:38:33.854 trace Z-Wave Node 0C: Repair is adding return routes
sys:12020-08-13 09:38:31.045 trace Z-Wave Node 0C: Repair is deleting routes
sys:12020-08-13 09:38:30.629 trace Z-Wave Node 0C: Repair is requesting device routeList
sys:12020-08-13 09:38:20.797 trace Z-Wave Node 0C: Repair is updating neighbors
sys:12020-08-13 09:38:20.791 trace Z-Wave Node 0C: Repair starting
sys:12020-08-13 09:38:13.531 trace Z-Wave Node 0B: Repair is done.
sys:12020-08-13 09:38:13.520 trace Z-Wave Node 0B: Repair is adding return routes
sys:12020-08-13 09:37:59.597 trace Z-Wave Node 0B: Repair is deleting routes
sys:12020-08-13 09:37:59.532 trace Z-Wave Node 0B: Repair is requesting device routeList
sys:12020-08-13 09:37:50.787 trace Z-Wave Node 0B: Repair is updating neighbors
sys:12020-08-13 09:37:50.769 trace Z-Wave Node 0B: Repair starting
sys:12020-08-13 09:37:43.014 trace Z-Wave Node 0A: Repair is done.
sys:12020-08-13 09:37:43.004 trace Z-Wave Node 0A: Repair is adding return routes
sys:12020-08-13 09:37:28.166 trace Z-Wave Node 0A: Repair is deleting routes
sys:12020-08-13 09:37:28.101 trace Z-Wave Node 0A: Repair is requesting device routeList
sys:12020-08-13 09:37:20.763 trace Z-Wave Node 0A: Repair is updating neighbors
sys:12020-08-13 09:37:20.745 trace Z-Wave Node 0A: Repair starting
sys:12020-08-13 09:37:14.783 trace Z-Wave Node 09: Repair is done.
sys:12020-08-13 09:37:14.772 trace Z-Wave Node 09: Repair is adding return routes
sys:12020-08-13 09:37:13.978 trace Z-Wave Node 09: Repair is deleting routes
sys:12020-08-13 09:37:13.904 trace Z-Wave Node 09: Repair is requesting device routeList
sys:12020-08-13 09:37:05.739 trace Z-Wave Node 09: Repair is updating neighbors
sys:12020-08-13 09:37:05.725 trace Z-Wave Node 09: Repair starting
sys:12020-08-13 09:37:01.617 trace Z-Wave Node 08: Repair is done.
sys:12020-08-13 09:37:01.614 trace Z-Wave Node 08: Repair is adding return routes
sys:12020-08-13 09:36:33.521 trace Z-Wave Node 08: Repair is deleting routes
sys:12020-08-13 09:36:33.025 trace Z-Wave Node 08: Repair is requesting device routeList
sys:12020-08-13 09:36:20.717 trace Z-Wave Node 08: Repair is updating neighbors
sys:12020-08-13 09:36:20.701 trace Z-Wave Node 08: Repair starting
sys:12020-08-13 09:36:16.042 trace Z-Wave Node 07: Repair is done.
sys:12020-08-13 09:36:16.032 trace Z-Wave Node 07: Repair is adding return routes
sys:12020-08-13 09:36:13.732 trace Z-Wave Node 07: Repair is deleting routes
sys:12020-08-13 09:36:13.668 trace Z-Wave Node 07: Repair is requesting device routeList
sys:12020-08-13 09:36:05.693 trace Z-Wave Node 07: Repair is updating neighbors
sys:12020-08-13 09:36:05.682 trace Z-Wave Node 07: Repair starting
sys:12020-08-13 09:36:01.239 trace Z-Wave Node 06: Repair is done.
sys:12020-08-13 09:36:01.231 trace Z-Wave Node 06: Repair is adding return routes
sys:12020-08-13 09:35:58.738 trace Z-Wave Node 06: Repair is deleting routes
sys:12020-08-13 09:35:58.664 trace Z-Wave Node 06: Repair is requesting device routeList
sys:12020-08-13 09:35:50.659 trace Z-Wave Node 06: Repair is updating neighbors
sys:12020-08-13 09:35:50.656 trace Z-Wave Node 06: Repair starting
sys:12020-08-13 09:35:45.608 infoStarting Z-Wave Network Repair
