Am currently in a hospital (just got surgery 12 hours ago) and i am unable to try from a desktop device at this time.
Currently trying from Safari on iPhone 11/iOS 16.6
HOWEVER!!!
Until this morning i have tried in the following:
macOS: safari, chrome, firefox developer edition - all the latest versions possible
windows 11: latest version of edge
on all browsers i have tried in incognito/private mode too
ios hubitat app
and they all produce the same outcome - the one i have described several times above
Sorry to hear about your surgery. Wishing you quick recovery. Your hub looks good from our end and it appears to run the latest version. If you are using VPN to access your hub, we have seen issues before. I suggest getting back to us once you are home and if you still have the same problems on your local network.
ok, i will get back to you! just know that all of the above has been tested from the local network (i am now trying with the vpn because of the reasons mentioned)
however since we are in very, very different time zones can you please provide me with a time frame when i can reach you, because waiting for a full day to get a reply just doesnโt work - if i have a timeframe i will be sure to message you when you will be able to respond! thank you!
Isn't there an endpoint to force a firmware update to the last release of a specific minor version? Maybe OPs problem is something with the firmware jump.
ok, @bobbyD - i am back home and i have made some more screenshots.
Here is what i see in google chrome (currently the hub is with the latest firmare):
@korgoth - is your home LAN a Class A, B, or C network? The hub defaults to thinking it is on a Class C network. I'm wondering if some of this redirection originates from a netmask issue.
The issue has been resolved. The Diagnostic Tool was updated since last time @korgoth ran a Soft Reset. Running a new Soft Reset from the latest version solved the problem.
