Button Controller has been upgraded in two respects. These new features are only available in newly created Button Controller instances. Your existing Button Controller instances will still use the previous version of Button Controller. You may choose to remove and recreate an old instance should you need any of these features for an existing instance.
Eight Buttons
You may now define actions for up to 8 different buttons in Button Controller (previously 7).
Integrated with Rule Machine
You can now run rules, run rule actions, run actions, set Private Boolean, stop actions, pause rules and resume rules from Button Controller.
Some of the drivers implement held in software, but double tap isn't something we would try in software.
So it's only available if the device provides it.
Not sure whether hubitat would treat these devices as buttons, but from what I’ve read in the ST forum there are z-wave switches by Homeseer and GE (the newest generation of z-wave plus switches, I think) that support double-tap.
I just updated to latest 1.1.1.118, which stated button controller 1.5 would be available... but when i remove and install button controller app, it says Version 1.0.0/---
The —- is for Button Controller, the 1.0 is the parent. Install one then you’ll see the version number. You have 1.5. We will fix the patent version number to remove the confusion.
@bravenel, is it possible to add the capability to trigger a RM Action in button controller? I have several actions set up to be called by multiple rules and buttons. I have created rules for the buttons but it would be nice to be able to contain everything under Button Controller.
