Built In Minoston Mini Power Meter Plug Driver reporting power draw every second!
So I have a few of these outlet plugs I got awhile back. I went to use one, set it up with the built in driver, and the thing is reporting power usage changes every second if they are changing even by 1watt.. I feel like this thing is going to flood my z-wave network with a lot of unnecessary traffic... I really only need it to report energy changes if greater than 50 watt or so..
I've tried two other drivers out there that I found, but those either don't have energy reporting, or they are also reporting every second.
Thanks!
  • Shane
Do any of the driver provide the option to change the reporting period or the change in power reading? Some drivers (I believe) can send commands of sorts to the physical device to tell it to only report on larger changes in certain readings. Not sure if that is the case for your devices, but at would encourage you to check the Device Edit page to see if there are any options in the Preferences section that could control this.
Simon
I am thinking you have the MP21ZP? Looks like it should have some parameters you can set to adjust the reporting. The driver may not expose them but they can be set manually.
https://products.z-wavealliance.org/products/4247/configs
You can use this driver to set any parameters you want (switch to it then switch back when done)
If you need more explanation just let us know, someone can explain it further I'm sure.
I discovered the hard way that Z-Wave config page is not correct. The correct settings parameters are in the manual that comes with it - and currently located here:
https://minoston.com/wp-content/uploads/2021/08/MP21ZP-%E8%AF%B4%E6%98%8E%E4%B9%A6.pdf
I was able to set it to 50W and that stopped it flooding the z-wave network.
Awesome, good to hear. Be aware if you SAVE with the driver that has the parameters wrong, it may inadvertently set it back how it was before. Is the driver you are using designed for your device / listed in the compatibility list? Or just one that happens to work? If so we should report it to the devs so they can get in there and fix it. According to the compatibility list the proper driver should be "Minoston Mini Power Meter Plug"
EDIT: I just realized that maybe you are saying the page I linked you to is wrong and the driver may not have any options in it? You used the manual to figure out the correct settings. Sorry for the bad info, that's not the first time I have found wrong info on that site, I guess I wont trust it any more.
That's correct.. That built in driver doesn't have the "Power" time report frequency and Wattage (difference) reporting parameters. So I had to switch the driver to the Basic Z-Wave tool driver and issue the parameter change there, then switch back to the built-in driver.
‒ Power Wattage(W) Report
This parameter determines the minimum change in power wattage(W) that will
result in sending new power report to the main controller.
Parameter =5, size=1byte, value=1W (default)
value range: 0—5W
‒ Time Report
This parameter determines minimum time that has to elapse before sending
Parameter =6, size=4byte, value=1Minute (default)
value range: 1—65535Minute
Thanks again!
  • Shane
I figured this'd be the easy part but I can't locate the energy report having followed the above guidance. I'd understood it was factory default anyway but nothing seems to work.
Any pointers?
Try using the driver that Minoston has posted on their site now. It should expose the settings and have all the features, making it much easier than what is posted above.
Direct link: https://minoston.com/wp-content/uploads/2023/01/MP21ZP-MP22ZP.zip
https://minoston.com/download-indoor-smart-plug-2/?swcfpc=1
Great, thanks!
The new driver is installed and is indeed exposing the necessary parameters in the driver UX. It's been installed for a little bit but I still can't find (or don't know where to look for) the power consumption logs: if it's in Logs, it isn't there yet; Events seems unlikely... can you give me a pointer, please.
The device page will have attributes with the reported power data.
You can see history of those attributes on the "Events" tab.
Not sure if that driver has a "Configure" button but you may need to run that and then a Refresh to populate everything initially.
Here is an example from a different device
Configuring didn't help so I tried a Reset--that resulted in the following with all values at null... seems reasonable following a reset so I waited a minute per my test config and came back and refreshed the device.
After the refresh, it reverted to this and power consumption states won't re-appear with just a refresh.
The only way to bring them (albeit all null) is to reset again which is apparently futile.
Any ideas?
PS: here's my Preferences in case it helps:
Seems like the device is not reporting anything.
Try setting the power report value changed to 5 and also change the minutes to 5, you don't want it reporting every minute.
Whatever you have plugged into it, turn it on and off as well, which should trigger the power report if its over 5w.
I set it to 1 min only to eliminate wait time. I've set both to 5 and it still reads null... and then ultimately, they all disappear necessitating another Reset and we're back at square one.
Any other ideas?
//EDIT: tried enabling it on another of my plugs, same result. Both are using the new driver. :man_shrugging: I'm updating the firmware now as a light ditch effort.
Are you certain you have the MP21ZP and not the MP21Z (no P) which does not do power monitoring?
Maybe it was switched in the box, or has the wrong internals, or the wrong label was applied?
I unplugged it and checked the label, it's a "P". I also just updated its firmware (which took an age) and now it's unresponsive... so there's that. I'll try excluding/resetting/including it and giving it another shot. If not, I might well have another "P" attached to something I care little about its power consumption.
Appreciate all the insights!
