I've borked up my app install by trying to delete and re-add the app. Now I can't get past this error:
There was a problem updating devices:
java.lang.NullPointerException: Cannot get property 'deviceNetworkId' on null object.
Line number: 611
Last successful step: Sensor Indexing
Any way to scrub my old install fully and start fresh? Maybe I have to shell into HE and nuke some directory? Thanks!
Ok, then it’s just as if you had installed by HPM.
You should just have to do a “Repair” on the MyQ Lite integration. If that doesn’t work, then here is what you have to do:
Delete any devices that are created by the MyQ Lite, as well as the app. To do this, open the MyQ Lite app and click the Uninstall button. This will break any rules you have created for the garage door opener, and will put a ? on the garage door tile. You can fix the tile after the new version is installed, fixing the rules is a little more difficult but depends on what you have done.
Then, go into HPM and click Repair. This will install new code for the app and drivers.
OK! All done! I had to add a user app to get it in the app list again, programmed it up, device created. I've added a MyQ gate opener today to the pre-existing garage door opener+sensor but there's no open/close sensor to pair it with the gate, so I think that's what the app was barfing on. I'll add a z-wave contact sensor to the gate later on. Thanks!
To add to what that lightening typist @thebearmay said, because Chamberlain will block IPs and accounts that poll the MyQ sensor. Dominick Meglio refuses to add that capability to his ported driver for that reason.
Just get a contact sensor and add it. That will also give you greater security in case someone tries to pry open your garage door.
Just to clear a misconception. Both the Hubitat MyQ app and the Chamberlain phone app connect to Chamberlain's cloud servers. Neither one of them talks directly to the MyQ hub.
Glad to see this app. I added it through package manager a little ways back and finally found a contact sensor (these things seem to be hard to come by lately?). Works great! The only flaw I see is that there is a button in the device driver for it to report "door moving" but it doesn't seem to report this as Alexa can't tell if the door is working after she sends the command.
I'm getting these log errors and I'm wondering if there's anything I can do to resolve it?
2022-04-08 02:46:31.083 pm errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_brbeaird_MyQ_Garage_Door_Opener_NoSensor_544.updateSensorBattery() is applicable for argument types: (java.math.BigDecimal) values: [100] (method updateSensorBattery)
Other than these constant log errors, the driver seems to work perfectly.
I do have sensors with this driver... when I have some extra time, maybe I'll double check the setup and possibly re-install the driver. Looking at thebearmay comment, it seems maybe those sensors didn't take during my install.
