### Link
https://www.amazon.com/dp/B0DNF4KK5G
### Database entry
{"id":27,"ty…pe":"Router","ieeeAddr":"0xa4c1380b136e2bee","nwkAddr":17551,"manufId":4417,"manufName":"_TZE204_1youk3hj","powerSource":"Mains (single phase)","modelId":"TS0601","epList":[1,242],"endpoints":{"1":{"profId":260,"epId":1,"devId":81,"inClusterList":[4,5,61184,0],"outClusterList":[25,10],"clusters":{"genBasic":{"attributes":{"65534":0,"stackVersion":0,"dateCode":"","manufacturerName":"_TZE204_1youk3hj","zclVersion":3,"appVersion":74,"modelId":"TS0601","powerSource":1}}},"binds":[],"configuredReportings":[],"meta":{}},"242":{"profId":41440,"epId":242,"devId":97,"inClusterList":[],"outClusterList":[33],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":74,"stackVersion":0,"hwVersion":1,"dateCode":"","zclVersion":3,"interviewCompleted":true,"meta":{"configured":1946894323},"lastSeen":1741303363887}
### Zigbee2MQTT version
2.1.3
### Comments
**Pairing Logs**
`info 2025-03-06 18:22:11z2m: Zigbee: allowing new devices to join.
info 2025-03-06 18:22:11z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254},"status":"ok","transaction":"lk1la-18"}'
info 2025-03-06 18:22:42zh:controller: Interview for '0xa4c1380b136e2bee' started
info 2025-03-06 18:22:42z2m: Device '0xa4c1380b136e2bee' joined
info 2025-03-06 18:22:42z2m: Starting interview of '0xa4c1380b136e2bee'
info 2025-03-06 18:22:42z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1380b136e2bee","ieee_address":"0xa4c1380b136e2bee"},"type":"device_joined"}'
info 2025-03-06 18:22:42z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1380b136e2bee","ieee_address":"0xa4c1380b136e2bee","status":"started"},"type":"device_interview"}'
info 2025-03-06 18:22:43zh:controller: Succesfully interviewed '0xa4c1380b136e2bee'
info 2025-03-06 18:22:43z2m: Successfully interviewed '0xa4c1380b136e2bee', device has successfully been paired
info 2025-03-06 18:22:43z2m: Device '0xa4c1380b136e2bee' is supported, identified as: NEO Human presence sensor (NAS-PS10B2)
info 2025-03-06 18:22:43z2m: Configuring '0xa4c1380b136e2bee'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c1380b136e2bee/presence/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"device_class":"presence","object_id":"0xa4c1380b136e2bee_presence","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_presence_zigbee2mqtt","value_template":"{{ value_json.presence }}"}'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Human presence sensor","exposes":[{"access":1,"description":"Indicates whether the device detected presence","label":"Presence","name":"presence","property":"presence","type":"binary","value_off":false,"value_on":true},{"access":1,"description":"Human Motion State","label":"Human motion state","name":"human_motion_state","property":"human_motion_state","type":"enum","values":["none","small","large"]},{"access":1,"description":"Current distance of detected motion","label":"Current distance","name":"dis_current","property":"dis_current","type":"numeric","unit":"cm","value_max":600,"value_min":0,"value_step":1},{"access":3,"description":"Presence Time","label":"Presence time","name":"presence_time","property":"presence_time","type":"numeric","unit":"s","value_max":600,"value_min":3,"value_step":1},{"access":3,"description":"Motion Range Detection","label":"Motion far detection","name":"motion_far_detection","property":"motion_far_detection","type":"numeric","unit":"cm","value_max":600,"value_min":150,"value_step":75},{"access":3,"description":"Motion Detection Sensitivity","label":"Motion sensitivity value","name":"motion_sensitivity_value","property":"motion_sensitivity_value","type":"numeric","value_max":7,"value_min":0,"value_step":1},{"access":3,"description":"Motionless Detection Sensitivity","label":"Motionless sensitivity","name":"motionless_sensitivity","property":"motionless_sensitivity","type":"numeric","value_max":7,"value_min":0,"value_step":1},{"access":3,"description":"Work Mode","label":"Work mode","name":"work_mode","property":"work_mode","type":"enum","values":["manual","auto"]},{"access":3,"description":"Output Switch","label":"Output switch","name":"output_switch","property":"output_switch","type":"binary","value_off":"OFF","value_on":"ON"},{"access":3,"description":"Output Times","label":"Output time","name":"output_time","property":"output_time","type":"numeric","unit":"s","value_max":1800,"value_min":10},{"access":3,"description":"Led Switch","label":"Led switch","name":"led_switch","property":"led_switch","type":"binary","value_off":"OFF","value_on":"ON"},{"access":3,"description":"Lux Value","label":"Lux value","name":"lux_value","property":"lux_value","type":"enum","values":["10 lux","20 lux","50 lux","24h"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"NAS-PS10B2","options":[],"supports_ota":false,"vendor":"NEO"},"friendly_name":"0xa4c1380b136e2bee","ieee_address":"0xa4c1380b136e2bee","status":"successful","supported":true},"type":"device_interview"}'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c1380b136e2bee/human_motion_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"name":"Human motion state","object_id":"0xa4c1380b136e2bee_human_motion_state","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_human_motion_state_zigbee2mqtt","value_template":"{{ value_json.human_motion_state }}"}'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c1380b136e2bee/dis_current/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"enabled_by_default":true,"name":"Current distance","object_id":"0xa4c1380b136e2bee_dis_current","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_dis_current_zigbee2mqtt","unit_of_measurement":"cm","value_template":"{{ value_json.dis_current }}"}'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c1380b136e2bee/presence_time/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/presence_time","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"max":600,"min":3,"name":"Presence time","object_id":"0xa4c1380b136e2bee_presence_time","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","step":1,"unique_id":"0xa4c1380b136e2bee_presence_time_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ value_json.presence_time }}"}'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c1380b136e2bee/motion_far_detection/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/motion_far_detection","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"max":600,"min":150,"name":"Motion far detection","object_id":"0xa4c1380b136e2bee_motion_far_detection","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","step":75,"unique_id":"0xa4c1380b136e2bee_motion_far_detection_zigbee2mqtt","unit_of_measurement":"cm","value_template":"{{ value_json.motion_far_detection }}"}'
info 2025-03-06 18:22:43z2m: Successfully configured '0xa4c1380b136e2bee'
info 2025-03-06 18:22:43z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c1380b136e2bee/motion_sensitivity_value/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/motion_sensitivity_value","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"max":7,"min":0,"name":"Motion sensitivity value","object_id":"0xa4c1380b136e2bee_motion_sensitivity_value","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","step":1,"unique_id":"0xa4c1380b136e2bee_motion_sensitivity_value_zigbee2mqtt","value_template":"{{ value_json.motion_sensitivity_value }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c1380b136e2bee/motionless_sensitivity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/motionless_sensitivity","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"max":7,"min":0,"name":"Motionless sensitivity","object_id":"0xa4c1380b136e2bee_motionless_sensitivity","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","step":1,"unique_id":"0xa4c1380b136e2bee_motionless_sensitivity_zigbee2mqtt","value_template":"{{ value_json.motionless_sensitivity }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/select/0xa4c1380b136e2bee/work_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/work_mode","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"name":"Work mode","object_id":"0xa4c1380b136e2bee_work_mode","options":["manual","auto"],"origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_work_mode_zigbee2mqtt","value_template":"{{ value_json.work_mode }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/switch/0xa4c1380b136e2bee/switch_output_switch/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/output_switch","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"name":"Output switch","object_id":"0xa4c1380b136e2bee_output_switch","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_switch_output_switch_zigbee2mqtt","value_template":"{{ value_json.output_switch }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/number/0xa4c1380b136e2bee/output_time/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/output_time","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"max":1800,"min":10,"name":"Output time","object_id":"0xa4c1380b136e2bee_output_time","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_output_time_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ value_json.output_time }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/switch/0xa4c1380b136e2bee/switch_led_switch/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/led_switch","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"name":"Led switch","object_id":"0xa4c1380b136e2bee_led_switch","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_switch_led_switch_zigbee2mqtt","value_template":"{{ value_json.led_switch }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/select/0xa4c1380b136e2bee/lux_value/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c1380b136e2bee/set/lux_value","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"name":"Lux value","object_id":"0xa4c1380b136e2bee_lux_value","options":["10 lux","20 lux","50 lux","24h"],"origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_lux_value_zigbee2mqtt","value_template":"{{ value_json.lux_value }}"}'
info 2025-03-06 18:22:44z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0xa4c1380b136e2bee/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"hw_version":1,"identifiers":["zigbee2mqtt_0xa4c1380b136e2bee"],"manufacturer":"NEO","model":"Human presence sensor","model_id":"NAS-PS10B2","name":"0xa4c1380b136e2bee","via_device":"zigbee2mqtt_bridge_0x048727fffe1bfc06"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c1380b136e2bee_linkquality","origin":{"name":"Zigbee2MQTT","sw":"2.1.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c1380b136e2bee","unique_id":"0xa4c1380b136e2bee_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":null,"human_motion_state":null,"led_switch":null,"linkquality":200,"lux_value":null,"motion_far_detection":null,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":null,"output_time":null,"presence":true,"presence_time":null,"work_mode":null}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":null,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":null,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":null,"output_time":null,"presence":true,"presence_time":null,"work_mode":null}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":null,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":null,"output_time":null,"presence":true,"presence_time":null,"work_mode":null}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":200,"lux_value":null,"motion_far_detection":null,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":"ON","output_time":null,"presence":true,"presence_time":null,"work_mode":null}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":null,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":null}'
info 2025-03-06 18:22:49z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":600,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":null}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":null,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":null}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":54,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":null}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":null,"motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":null}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":null,"linkquality":200,"lux_value":null,"motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":null,"linkquality":200,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":null,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":null,"linkquality":200,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":null,"linkquality":196,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"small","led_switch":"ON","linkquality":200,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":71,"human_motion_state":"large","led_switch":"ON","linkquality":196,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:50z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":109,"human_motion_state":"large","led_switch":"ON","linkquality":196,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:51z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":176,"human_motion_state":"large","led_switch":"ON","linkquality":196,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:52z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":196,"human_motion_state":"large","led_switch":"ON","linkquality":196,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'
info 2025-03-06 18:22:53z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b136e2bee', payload '{"dis_current":196,"human_motion_state":"small","led_switch":"ON","linkquality":200,"lux_value":"24h","motion_far_detection":600,"motion_sensitivity":3,"motion_sensitivity_value":null,"motionless_sensitivity":3,"output_switch":"ON","output_time":10,"presence":true,"presence_time":5,"work_mode":"auto"}'`
### External definition
```shell
const definition = {
zigbeeModel: ['TS0601'],
model: 'TS0601',
vendor: '_TZE204_1youk3hj',
description: 'Automatically generated definition',
extend: [],
meta: {},
module.exports = definition;
### What does/doesn't work with the external definition?
So this device is already "supported" and mostly works, except for a few issues:
**Issue 1**
I am unable to adjust motion sensitivity. This is a critical parameter, without it I am unable to tweak the sensor to work for my situation. When I try to do that, I get this error in the logs:
`error 2025-03-06 18:23:57z2m: Publish 'set' 'motion_sensitivity_value' to '0xa4c1380b136e2bee' failed: 'Error: No datapoint defined for 'motion_sensitivity_value''`
I read that if you have a Tuya hub you might be able to use it to get the datapoint, but I don't have one so hopefully there is some other way?
**Issue 2**
When I set Work Mode to 'Manual' it still behaves like it's in 'Auto' mode. Meaning the output turns on when presence is detected and off when presence is no longer detected. I am unsure if this is just a limitation of the device or an issue with Z2M. The logs show it's in manual mode but the output is still controlled by presence.
