[RELEASE] Tuya Zigbee Multi-Sensor 4 In 1 (PIR motion sensors) w/ healthStatus
Called ChatGPT for a help - this is the result (to be double-checked manually, never trust 100% ChatGPT! :slight_smile: )
Model Sensing hardware & role What it exposes (Zigbee2MQTT) Notable options Power
ZG-204ZL
inClusters: "0000,0003,0500,EF00,0001,0400", model:"ZG-204ZL", manufacturer:"HOBEIAN"
PIR + Lux (no radar) → classic motion/illuminance occupancy, illuminance, battery + sensitivity (low/med/high), keep_time, illuminance_interval Simple PIR tuning (keep-time, sensitivity). Coin cell CR2450 (vendor spec for Z/ZL family). (Zigbee2MQTT)
ZG-204ZV
inClusters: '0000,0003,0500,EF00,0402,0405,0001,0400', manufacturer: 'HOBEIAN', model: 'ZG-204ZV'
mmWave presence model with temp & humidity (no PIR listed) presence, illuminance, temperature, humidity, battery + fading_time, indicator, illuminance_interval, motion_detection_sensitivity Has temp/humidity calibration; presence only (no PIR “occupancy”). (Battery not stated in docs page; varies by seller.) (Zigbee2MQTT)
ZG-204ZM
In Clusters: '0000,0003,0500,EF00,0001,0400', Manufacturer: 'HOBEIAN', Model: 'ZG-204ZM'
PIR + 24 GHz mmWave combo → presence + motion state + lux presence, motion_state {none, small, large, static}, illuminance, battery + fading_time, static_detection_distance, static_detection_sensitivity, motion_detection_mode {only_pir, pir_and_radar, only_radar} (fw ≥ 0122052017), motion_detection_sensitivity, indicator Full mmWave tuning and PIR↔radar mode switch (on newer firmware). 2×AAA (review teardown/spec). (Zigbee2MQTT)
