Hi All
Please see logs seems like an issue with dev167 any thoughts?
refresh shows 6 devices, initialize gives an authorisation error!
search
dev:1672022-01-15 16:38:28.050 debugApp exception stack trace:
dev:1672022-01-15 16:38:28.045 errorConservatory Door Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:28.041 infoCreating device Conservatory Door Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:28.039 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:28.017 debugDevice Data: [active_time:1642244390, biz_type:0, category:cl, create_time:1642244390, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bfa8291b4d44cbbf3f826h, ip:81.99.29.197, lat:53.0798, local_key:17e9a2c3f5c509ae, lon:-1.1584, model:24,25.35.45, name:Conservatory Door Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:open], [code:percent_control, value:100], [code:percent_state, value:90], [code:work_state, value:opening], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262273, uuid:3234221c673f0e3c, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:28.030 debugApp exception stack trace:
dev:1672022-01-15 16:38:28.029 errorConservatory Door Right Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:28.024 infoCreating device Conservatory Door Right Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:28.014 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:28.018 debugApp exception stack trace:
dev:1672022-01-15 16:38:28.016 errorConservatory Door Left Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:27.968 debugDevice Data: [active_time:1642246747, biz_type:0, category:cl, create_time:1633067332, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bf64b034e0c63b8144ip3h, ip:81.99.29.197, lat:53.0798, local_key:73d7543afee1078b, lon:-1.1584, model:24,25.35.45, name:Conservatory Door Right Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:open], [code:percent_control, value:0], [code:percent_state, value:0], [code:work_state, value:opening], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262274, uuid:14ab22cd3244d7c1, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:28.012 infoCreating device Conservatory Door Left Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:28.009 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:27.976 debugDevice Data: [active_time:1642246746, biz_type:0, category:cl, create_time:1633875409, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bf54e1c3797be895993fec, ip:81.99.29.197, lat:53.0798, local_key:4cbd41b867c9df44, lon:-1.1584, model:24,25.35.45, name:Conservatory Door Left Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:open], [code:percent_control, value:0], [code:percent_state, value:0], [code:work_state, value:opening], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262275, uuid:e50026a075e85ad2, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:27.955 debugApp exception stack trace:
dev:1672022-01-15 16:38:27.932 debugApp exception stack trace:
dev:1672022-01-15 16:38:27.930 errorConservatory Bay Right Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:27.925 infoCreating device Conservatory Bay Right Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:27.923 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:27.904 debugDevice Data: [active_time:1642244394, biz_type:0, category:cl, create_time:1642244394, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bf0c44be5b7e667567jrfd, ip:81.99.29.197, lat:53.0798, local_key:e59c23d4a5b22755, lon:-1.1584, model:24,25.35.45, name:Conservatory Bay Right Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:stop], [code:percent_control, value:99], [code:percent_state, value:70], [code:work_state, value:opening], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262281, uuid:93600484de504234, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:27.912 debugApp exception stack trace:
dev:1672022-01-15 16:38:27.908 errorConservatory Bay Front Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:27.908 errorConservatory Bay Left Blind device creation failed: com.hubitat.app.exception.UnknownDeviceTypeException: Device type 'Generic Component Window Shade' in namespace 'component' not found at line null (null)
dev:1672022-01-15 16:38:27.888 infoCreating device Conservatory Bay Front Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:27.886 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:27.858 debugDevice Data: [active_time:1642246746, biz_type:0, category:cl, create_time:1633067332, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bf6859692a90b32d64vrfs, ip:81.99.29.197, lat:53.0798, local_key:d67dacc26a1ddb78, lon:-1.1584, model:24,25.35.45, name:Conservatory Bay Front Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:stop], [code:percent_control, value:0], [code:percent_state, value:0], [code:work_state, value:closing], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262281, uuid:472aea309757d5f1, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:27.871 infoCreating device Conservatory Bay Left Blind using Generic Component Window Shade driver
dev:1672022-01-15 16:38:27.864 debugTuya category cl driver [namespace:component, driver:Generic Component Window Shade]
dev:1672022-01-15 16:38:27.853 debugDevice Data: [active_time:1642246748, biz_type:0, category:cl, create_time:1633067821, icon:smart/icon/ay1535532217868NsRD0/f04797054f44b74527e91d486380e660.png, id:bf4c58958b3640c54cj0xa, ip:81.99.29.197, lat:53.0798, local_key:429fde4aec7cc41f, lon:-1.1584, model:24,25.35.45, name:Conservatory Bay Left Blind, online:true, owner_id:48172603, product_id:ytm1o7r6aj2qjxjn, product_name:Wifi卷帘电机, status:[[code:control, value:stop], [code:percent_control, value:7], [code:percent_state, value:7], [code:work_state, value:closing], [code:situation_set, value:fully_open]], sub:false, time_zone:+00:00, uid:eu1641852547535bdv8P, update_time:1642262275, uuid:ae137012ce94f06a, functions:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer]], statusSet:[control:[range:[open, stop, close, continue], type:Enum], percent_control:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], percent_state:[unit:%, min:0, max:100, scale:0, step:1, type:Integer], work_state:[range:[opening, closing], type:Enum], situation_set:[range:[fully_open, fully_close], type:Enum]]]
dev:1672022-01-15 16:38:27.846 warnCheck you have the Smart Home Scene Linkage service enabled for your Tuya account
dev:1672022-01-15 16:38:27.838 errorCloud API request failed: {"code":28841101,"msg":"No permissions. This API is not subscribed.","success":false,"t":1642264705861}
dev:1672022-01-15 16:38:27.756 warnCheck you have the Smart Home Scene Linkage service enabled for your Tuya account
dev:1672022-01-15 16:38:27.751 errorCloud API request failed: {"code":28841101,"msg":"No permissions. This API is not subscribed.","success":false,"t":1642264705843}
dev:1672022-01-15 16:38:27.603 debugAPI GET [uri:https://openapi.tuyaeu.com, path:/v1.0/devices/bfa8291b4d44cbbf3f826h/specifications, query:null, contentType:application/json, headers:[t:1642264707601, nonce:5ede9823-810d-42fa-9f62-fb94b27bc8b3, client_id:ccjurt8yb8z8d4kefjty, Signature-Headers:client_id, sign:80475DDA86EDF6249F5EB4A6345E409A2B16CD7A4BB447C265FA7F934B2CC168, sign_method:HMAC-SHA256, access_token:b4fb1951150be22ed7669d4f7ef5929d, lang:en, dev_lang:groovy, dev_channel:hubitat, devVersion:0.2.3], body:null, timeout:5]
