First beta release of an updated inovelli 4in1 sensor driver..
Main new feature is the ability to set the temperature change threshold in degrees F or degrees C based on location settings.. It will convert it to the proper parameter value of 1-500 in .1 degrees C .. It also shows appropriate range based on actual degrees..
I am trying to get this device to behave like a mains powered device when the USB is plugged in.. Haven't found a way yet...
