M6TTL
October 15, 2023, 12:02am
21
I enabled the debug log and this is what I'm seeing when I press the up and down buttons.
dev:27162023-10-14 04:59:01.139 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x00, data: [], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x5154, isClusterSpecific: true, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x00, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0040)
dev:27162023-10-14 04:59:01.135 PMdebugParse description catchall: 0104 0006 01 01 0040 00 5154 01 00 0000 00 00
dev:27162023-10-14 04:58:59.564 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x00, data: [], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x5154, isClusterSpecific: true, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0040)
dev:27162023-10-14 04:58:59.559 PMdebugParse description catchall: 0104 0006 01 01 0040 00 5154 01 00 0000 01 00
Anything catch your eye with these messages?
BMX4605
October 15, 2023, 7:18pm
22
Yes. It looks like you pressed the UP button (button #1 ) & then the DN button (button #3 ). Here is my log:
dev:20122023-10-15 03:13:25.295 PMdebugbuttons 1 or 3 pressed
dev:20122023-10-15 03:13:25.292 PMdebugclusterId= 6, Msg.command= 0, atomicState.releasecalled 0
dev:20122023-10-15 03:13:25.290 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x00, data: [], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x587d, isClusterSpecific: true, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x00, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0040)
dev:20122023-10-15 03:13:25.285 PMdebugParse description catchall: 0104 0006 01 01 0040 00 587D 01 00 0000 00 00
dev:20122023-10-15 03:13:21.888 PMdebugbuttons 1 or 3 pressed
dev:20122023-10-15 03:13:21.884 PMdebugclusterId= 6, Msg.command= 1, atomicState.releasecalled 0
dev:20122023-10-15 03:13:21.880 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x00, data: [], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x587d, isClusterSpecific: true, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0040)
dev:20122023-10-15 03:13:21.874 PMdebugParse description catchall: 0104 0006 01 01 0040 00 587D 01 00 0000 01 00
BMX4605
October 15, 2023, 7:21pm
23
here is an image of the device when I press button #1 (UP)
BMX4605
October 15, 2023, 7:23pm
24
Here is an image of the device when I press button #3 (DN)
BMX4605
October 15, 2023, 7:24pm
25
You can see pushed changes from 1 to 3.
M6TTL
October 15, 2023, 11:05pm
26
This is very strange. When I push up and down, the "current states" does not show that any buttons are pushed. If I switch back to the original driver code, it will show that the buttons are pushed. Maybe I should try removing the device.. re-add, then choose your driver.
M6TTL
October 15, 2023, 11:35pm
27
After removing and re-pairing the device two times and switching back and forth between the different device types, I was able to get your driver to register button presses, but then after I tried holding one of the side buttons, it stopped registering the button presses again. This is super weird.
BMX4605
October 17, 2023, 5:24am
28
I updated the code (download from https://github.com/BMX4605/Hubitat/blob/main/Drivers/IKEA%20Styrbar/IKEA%20Styrbar.groovy ) to further correct the behavior of buttons 2 or 4 held/released. new version is 0.1.2.
Make sure you enable the following on your device:
Enable debug logging
Enable descriptionText logging
ive just got one of these today, its paired okay, but it doesnt register button pushes or anything in the logs, ive reset an paired it quite a few times now, no luck
have a look at these drivers - much more up to date for all things IKEA, especially STYRBAR
Here are the Zigbee drivers I created for the IKEA smart products that I own.
From browsing this forum, I gathered that some IKEA products were not usable with Hubitat because they were using incoming group messaging. The problem was fixed in newer firmwares, so please upgrade to the latest versions before using these drivers (tip: you can do the update directly from Hubitat ) .
Supported devices (17)
Askvader On/Off Switch (E1836) <a href="https://dan-danache.github.io/hubitat/ikea-zigb…
Hi there. Did you ever get your to work?
