Good luck , here all day if you need ..
Please note publish the status to MQTT 'retained'
It maybe more aesthetic to choose Indigo/motion/sensor1 as your topic then all your motion sensors are grouped under Indigo/motion
Success!
Works a treat. Thanks for the detailed step-by-step instructions.
I am not using temperature, so I guess the temperature_MAP of [inactive,active] doesn't matter?
So I presume this approach will work with most/all Virtual device types?
Should do - and if it doesn't I can 'make it so'
Just leave temperature blank - this applies to any attribute you don't want to use within a device driver.
I am making progress with interpreting the topics published by the App for use in Indigo.
My much preferred option is to process published topics in the homie 3 protocol but with Complete & compliant homie topics turned off.
Ideally I want to make use of the topic $nodes but it seems this is only created if you have Complete & compliant homie topics turned on. Is there a way to get this topic to be published with just the homie 3 protocol selected?
Currently not - you would have to leave complete and compliant turned on. If you turn it off then people wanted an absolute minimal set of topics. You can choose what you subscribe to so no extra load on Indigo.
Or you could alter the code to suit what you need....
@autologI I was looking in the next beta3e and I see that $nodes is published when complete homie3 topics are turned off so that might suit you ? I can see it's useful. I don't remember adding that so I would expect it to be published currently but my memory is questionable nowadays
@kevin Thanks for the update. Is there an ETA for beta3E?
'Soon'
But had a month or two break and now back looking at it - there's no serious bugs in 3d so 3e is just extra bits and a fix for the rogue child device creation on initial install
Beta 3e is about to land hopefully this weekend and so this is the last call for any bugs or feature requests or any patches that you may have that I haven't confirmed as being merged..... All Github reported merges have been done.
If you have a pull request ask for the latest code to merge against.
Beta 3e should be the last beta, assuming no bugs are found, and then it will become the release version.
There will still be some areas like homie discovery that will be expanded over time
Just curious if you ever got this sorted out. I'm looking to do something similar. Would like to use the Ecobee state changes (read locally by HA and "pushed" into HE) to trigger HE rules.
I have a new device driver called 'Remote Thermostat' that I think accomplishes this. It has no 'smarts' so is purely a virtual device for a remote MQTT thermostat managed by some other controller/device. That's available now should you want ?
There maybe other such remote devices needed where the virtual driver within HE has some smarts and therefore is in conflict with a remote device. Perhaps window shade is the simplest of such an example with it's timed behaviour.
Hi @kevin,
Further to my post number 333 and your reply, re: pressure.
The App doesn't seem to properly support publishing pressure AFAICS.
I have an Aqara Temperature/Humidity/Pressure device which has events like this:
and this is what is shown in MQTT Explorer:
Note that no pressure is shown.
Details from the device page, Sates:
and pressure units:
So I have tinkered with the MQTT App by adding the following code after line 4705:
else if (xType=='pressure'){ category='pressure' if (!atomicState.suppress){ mqtt.publishMsg (sTopic+'/'+category+'/$datatype',"integer",1,true,atomicState.suppress) mqtt.publishMsg (sTopic+'/'+category+'/$unit','mBar',1,true,atomicState.suppress) mqtt.publishMsg (sTopic+'/'+category+'/$format','750:1500',1,true,atomicState.suppress) } UOM="mBar" HAtype="sensor" }
The pressure is now showing:
However, I don't really know what I am doing with the groovy code but thought I would share. ![]()
Also when I look at the debug log for the MQTT App, I am seeing these warnings in the log -
For my Aeotec MultiSensor 6:
MQTT: Unknown property value ultravioletIndex
MQTT: Unknown property value tamper
MQTT: Unknown property value powerSource
For my Secure SRT321 Thermostat:
MQTT: Unknown property value checkInterval
Some more detail on the Aeotec MultiSensor 6 in case it is usefull:
app:1322021-01-27 14:10:59.687 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_humidity type: humidity / humidity state: 58 multiple: true
app:1322021-01-27 14:10:59.676 debugMQTT: [s] Unknown Category for type firmware reported by device Study Multi-Sensor
app:1322021-01-27 14:10:59.666 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_firmware type: firmware / firmware state: null multiple: true
app:1322021-01-27 14:10:59.654 debugMQTT: [s] Unknown Category for type ultravioletIndex reported by device Study Multi-Sensor
app:1322021-01-27 14:10:59.645 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_ultravioletIndex type: ultravioletIndex / ultravioletIndex state: null multiple: true
app:1322021-01-27 14:10:59.559 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_illuminance type: illuminance / illuminance state: 0 multiple: true
app:1322021-01-27 14:10:59.507 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_motion type: motion / motion state: inactive multiple: true
app:1322021-01-27 14:10:59.496 debugMQTT: [s] Unknown Category for type tamper reported by device Study Multi-Sensor
app:1322021-01-27 14:10:59.487 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_tamper type: tamper / tamper state: clear multiple: true
app:1322021-01-27 14:10:59.475 debugMQTT: [s] Unknown Category for type powerSource reported by device Study Multi-Sensor
app:1322021-01-27 14:10:59.467 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_powerSource type: powerSource / powerSource state: battery multiple: true
app:1322021-01-27 14:10:59.422 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_battery type: battery / battery state: 100 multiple: true
app:1322021-01-27 14:10:59.376 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_temperature type: temperature / temperature state: 18.1 multiple: true
app:1322021-01-27 14:10:59.294 debugMQTT: sensorDevices (synch) called with name:Study Multi-Sensor xName: Study Multi-Sensor_acceleration type: acceleration / acceleration state: inactive multiple: true
and more detail on the SRT321 in case it is useful:
app:1322021-01-27 14:11:00.442 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.438 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_thermostatOperatingState type: thermostatOperatingState / thermostatOperatingState state: heating multiple: true
app:1322021-01-27 14:11:00.422 infoMQTT: [t] Unknown category for type #switch# reported by device Study Thermostat
app:1322021-01-27 14:11:00.416 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.412 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_switch type: switch / switch state: null multiple: true
app:1322021-01-27 14:11:00.388 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.384 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_coolingSetpoint type: coolingSetpoint / coolingSetpoint state: null multiple: true
app:1322021-01-27 14:11:00.347 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.343 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_supportedThermostatFanModes type: supportedThermostatFanModes / supportedThermostatFanModes state: null multiple: true
app:1322021-01-27 14:11:00.308 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.304 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_heatingSetpoint type: heatingSetpoint / heatingSetpoint state: 20.0 multiple: true
app:1322021-01-27 14:11:00.269 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.265 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_thermostatFanMode type: thermostatFanMode / thermostatFanMode state: null multiple: true
app:1322021-01-27 14:11:00.237 infoMQTT: [t] Unknown category for type #checkInterval# reported by device Study Thermostat
app:1322021-01-27 14:11:00.231 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.228 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_checkInterval type: checkInterval / checkInterval state: 600 multiple: true
app:1322021-01-27 14:11:00.192 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.188 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_thermostatSetpoint type: thermostatSetpoint / thermostatSetpoint state: 20.0 multiple: true
app:1322021-01-27 14:11:00.164 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.160 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_supportedThermostatModes type: supportedThermostatModes / supportedThermostatModes state: null multiple: true
app:1322021-01-27 14:11:00.153 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.148 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_schedule type: schedule / schedule state: null multiple: true
app:1322021-01-27 14:11:00.112 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.108 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_battery type: battery / battery state: 62 multiple: true
app:1322021-01-27 14:11:00.072 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.068 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_temperature type: temperature / temperature state: 18.7 multiple: true
app:1322021-01-27 14:11:00.033 infoMQTT: [t] Unknown category for type #batteryLastReplaced# reported by device Study Thermostat
app:1322021-01-27 14:11:00.025 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:11:00.019 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_batteryLastReplaced type: batteryLastReplaced / batteryLastReplaced state: Tue Jan 05 12:52:03 GMT 2021 multiple: true
app:1322021-01-27 14:10:59.972 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:10:59.969 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_thermostatMode type: thermostatMode / thermostatMode state: heat multiple: true
app:1322021-01-27 14:10:59.932 warnMQTT: NB: Study Thermostat attribute_MAP's not yet supported
app:1322021-01-27 14:10:59.928 debugMQTT: thermostatDevices (synch) called with name:Study Thermostat xName: Study Thermostat_temperature type: temperature / temperature state: 18.7 multiple: true
As always, thanks for your help. ![]()
A lot of these capabilities are just things that the app doesn't support publishing onto MQTT yet like batteryLastReplaced, lastCheckinEpoch and mappings in some thermostat capabilities. Are you enabling these devices using the 'everything' (every capability) dropdown ?
Pressure however is something that should be supported and I'll add that. I had thought it worked TBH but that's maybe in the next beta. You need a bit more code than the few lines above to handle things like /set for the device and $settable, even though it isn't and you have hard coded the pressure units.
Hi Kevin, Yes I selected "every capability". I am not saying I need all those things, I was just drawing it your attention. Yes, I realise my code wasn't enough but lack the groovy skills and HE knowledge to do a proper pull request for you. Thanks for adding in pressure.
Hey @kevin ...I told you I'd be looking for your help soon!
I've got my ecobee thermostat and Mosquitto properly set up in Home Assistant and have moved on to getting your Hubitat MQTT App set up properly. I've followed installation steps 1 and 2 from the readme, but step three says:
- Configure this device to access your existing MQTT broker using the 'Preferences' section on the next screen in the device driver then click 'Done'. You must enter the IP (or URL) e.g. tcp://192.168.1.78:1883 , username / password are only required if your broker needs them. NB include tcp:// at the start of the entry.
I have two MQTT devices in my device list. One is the virtual device I created as part of step 2, the other is a child device created by the MQTT app. Neither of them has any "preferences" that can be set.
What have I missed?
You’ve fallen foul of outdated instructions. Delete both these MQTT child devices (not the driver code) and reboot the hub. Another child device will be automatically created. Now the broker address (in you case HA’s) can be entered within the MQTT app (MQTT Broker option) use any user/password that works.
Deleting the two devices and rebooting worked like a charm. I've now got 8 Home Assistant devices detected in the Hubitat app!
I've got two new problems, though. First, my actual ecobee thermostat is not one of them. I'll set that to the side for later. The second problem is that even the devices that were detected don't show their correct states. Take the Ecobee's remote temperature sensor, for example... no temperature value is available.
Also, now that my problems have progressed into the HA portion of the app, I can move to the dedicated MQTT/statestream thread.
Yes please... what do I need to do?
I'll PM you Dylan as this may require beta3e as the discovery mechanism via homie or HA Statestream in your case has to autocreate the correct device. There's possibly a few other things I need to go through with you personally to get you up and running. Are HA lights etc working OK for you ?
beta3e will be out shortly - just working on the 'everything' capability dropdown as it has become broken in next beta
I have nothing else in HA besides the ecobee and it's remote sensor. None of the states/attributes appear to be updating within HE.
I don't really have anything else to add into HA for testing...
