FYI - getting the following debug log on Echo Speak with debug logging turned off:
these will quiet down in next beta update
Since Saturday my Heroku process keeps receiving a SIGTERM and stopping. If I restart it then it runs for a short time with the same result. I canβt see any obvious error in the HE logs. Has anyone else experienced this?
2021-03-15T07:00:41.448876+00:00 app[web.1]: 3-15-2021 - 7:00:41am info: ** ServerVersion Sent to Hubitat Cloud Endpoint Successfully! **
2021-03-15T07:00:41.733772+00:00 app[web.1]: 3-15-2021 - 7:00:41am info: Server Version is Up-to-Date.
2021-03-15T07:31:53.285806+00:00 heroku[web.1]: Idling
2021-03-15T07:31:53.290696+00:00 heroku[web.1]: State changed from up to down
2021-03-15T07:31:54.633695+00:00 heroku[web.1]: Stopping all processes with SIGTERM
2021-03-15T07:31:54.720054+00:00 app[web.1]: SIGTERM
2021-03-15T07:31:54.731745+00:00 app[web.1]: clean
2021-03-15T07:31:54.731944+00:00 app[web.1]: 0
2021-03-15T07:31:54.732043+00:00 app[web.1]: graceful setting timeout for PID: 4
2021-03-15T07:31:54.884503+00:00 heroku[web.1]: Process exited with status 0
If I have a rule fire that would send speach to an echo, I see nothing that's an error in the logs, but the echo doesn't speak:
Summary
app:272021-03-15 08:33:19.059 debugaddToQ (multi) | Command(3): [command:volume, value:60, deviceData:[deviceType:A3VRME03NAXFUB, serialNumber:G0014C05946401HU, owner:A15DOGFY8UCU70, account:A05309264ICDCPWQOQYK, dni:27|echoSpeaks|G0014C05946401HU]]
app:272021-03-15 08:33:19.058 debugaddToQ (multi) | Command(2): [command:speak, value:Front door is open!, deviceData:[deviceType:A3VRME03NAXFUB, serialNumber:G0014C05946401HU, owner:A15DOGFY8UCU70, account:A05309264ICDCPWQOQYK, dni:27|echoSpeaks|G0014C05946401HU], cmdType:sendSpeak]
app:272021-03-15 08:33:19.056 debugaddToQ (multi) | Command(1): [command:volume, value:80, deviceData:[deviceType:A3VRME03NAXFUB, serialNumber:G0014C05946401HU, owner:A15DOGFY8UCU70, account:A05309264ICDCPWQOQYK, dni:27|echoSpeaks|G0014C05946401HU]]
app:272021-03-15 08:33:19.055 debugaddToQ (multi) | srcDesc: sendSpeak from 27|echoSpeaks|G0014C05946401HU
app:272021-03-15 08:33:19.054 debugaddToQ (multi) | callback: finishSendSpeak
app:272021-03-15 08:33:19.053 debugaddToQ (multi) | device: 27|echoSpeaks|G0014C05946401HU
app:272021-03-15 08:33:19.052 debugaddToQ (multi) | time: 1615797199036
app:272021-03-15 08:33:19.050 debugaddToQ (multi) | cmdMap: [cmdDesc:SpeakCommand, message:Front door is open!, newVolume:80, oldVolume:60, cmdDt:1615797198995, cmdId:285, deviceType:A3VRME03NAXFUB, serialNumber:G0014C05946401HU, owner:A15DOGFY8UCU70, account:A05309264ICDCPWQOQYK, dni:27|echoSpeaks|G0014C05946401HU]
app:272021-03-15 08:33:19.049 debugaddToQ NEW COMMAND
app:272021-03-15 08:33:19.033 traceEchoApp (v4.0.9.3) | sendSpeak cmdMap: [cmdDesc:SpeakCommand, message:Front door is open!, newVolume:80, oldVolume:60, cmdDt:1615797198995, cmdId:285, deviceType:A3VRME03NAXFUB, serialNumber:G0014C05946401HU, owner:A15DOGFY8UCU70, account:A05309264ICDCPWQOQYK, dni:27|echoSpeaks|G0014C05946401HU] callback: finishSendSpeak, device: 27|echoSpeaks|G0014C05946401HU
app:272021-03-15 08:33:18.971 debugaddToQ (multi) | Command(3): [command:volume, value:30, deviceData:[deviceType:A3RMGO6LYLH7YN, serialNumber:G2A1A6030382033F, owner:A15DOGFY8UCU70, account:A00488153DFD116WPDY2T, dni:27|echoSpeaks|G2A1A6030382033F]]
app:272021-03-15 08:33:18.969 debugaddToQ (multi) | Command(2): [command:speak, value:Front door is open!, deviceData:[deviceType:A3RMGO6LYLH7YN, serialNumber:G2A1A6030382033F, owner:A15DOGFY8UCU70, account:A00488153DFD116WPDY2T, dni:27|echoSpeaks|G2A1A6030382033F], cmdType:sendSpeak]
app:272021-03-15 08:33:18.968 debugaddToQ (multi) | Command(1): [command:volume, value:80, deviceData:[deviceType:A3RMGO6LYLH7YN, serialNumber:G2A1A6030382033F, owner:A15DOGFY8UCU70, account:A00488153DFD116WPDY2T, dni:27|echoSpeaks|G2A1A6030382033F]]
app:272021-03-15 08:33:18.967 debugaddToQ (multi) | srcDesc: sendSpeak from 27|echoSpeaks|G2A1A6030382033F
app:272021-03-15 08:33:18.966 debugaddToQ (multi) | callback: finishSendSpeak
app:272021-03-15 08:33:18.965 debugaddToQ (multi) | device: 27|echoSpeaks|G2A1A6030382033F
app:272021-03-15 08:33:18.898 debugaddToQ (multi) | time: 1615797198881
app:272021-03-15 08:33:18.896 debugaddToQ (multi) | cmdMap: [cmdDesc:SpeakCommand, message:Front door is open!, newVolume:80, oldVolume:30, cmdDt:1615797198838, cmdId:110, deviceType:A3RMGO6LYLH7YN, serialNumber:G2A1A6030382033F, owner:A15DOGFY8UCU70, account:A00488153DFD116WPDY2T, dni:27|echoSpeaks|G2A1A6030382033F]
app:272021-03-15 08:33:18.893 debugaddToQ NEW COMMAND
app:272021-03-15 08:33:18.878 traceEchoApp (v4.0.9.3) | sendSpeak cmdMap: [cmdDesc:SpeakCommand, message:Front door is open!, newVolume:80, oldVolume:30, cmdDt:1615797198838, cmdId:110, deviceType:A3RMGO6LYLH7YN, serialNumber:G2A1A6030382033F, owner:A15DOGFY8UCU70, account:A00488153DFD116WPDY2T, dni:27|echoSpeaks|G2A1A6030382033F] callback: finishSendSpeak, device: 27|echoSpeaks|G2A1A6030382033F
The server will be down 95% of the time. It's only used for login and cookie refresh
Thanks, gradually came to realise that as everything else around it appeared ok.
My speech problem appears solved. Tried updating to most recent update, got one test to work, but nothing after that. Restarted the hub, and additional visited the pistons (changed logging level), and finally its working.
No idea what went wrong. Did discover an error trying to enable child device debug logs (similar for trace too)
2021-03-15 17:39:52.761 errorgroovy.lang.MissingMethodException: No signature of method: user_driver_tonesto7_Echo_Speaks_WS_409.enableDebugLog() is applicable for argument types: () values: [] (enableDebugLog)
We'll fix this missing method in next update.
I've pushed up the fix but didn't increase the version. Please update the socket device manually.
@nh.schottfam, anything on this, post 140 above?
Sorry my cookie still has not rest its almost 22 days old and actions will not run. Any advice or direction? I didnt want to uninstall and reinstall as a lot of my automations are set up with it?
That message suggests it cannot reach your echo speaks server.
So you want to investigate heroku or you local server (if it is up, configured properly, what are the settings in the Echo speaks app., network connectivity)
Ah seems like heroku has decided to delete my application for some strange reason? Will redeploy tomorrow. Hopefully will be fixed, thanks for taking the time to assist me.
EDIT: Redeployed = All working now. Thank you.
Still needing regular reboots to keep the voice working. Are we any closer to the root cause and can i help in any way to identify the issue?
Will need to provide logs in a private message.
Would be good to also run individual device commands for speak() with logs on for ES application.
So some of you have noticed some new things in the latest beta changes:
most commands are now sent by the main ES app (so it can coordinate commands, parallelize commands, and control Alexa api throttling).
- so if you are sending logs, do include logs from the main ES app
a zone can create a virtual zone device
- it does not have all commands, but it has many to make a zone usable by webCoRE, rules machine or other apps
There is a new 'parallelSpeak' command
- This sends speak commands in parallel
for example, if you have a list of devices, your application can loop thru and send parallel speak (vs regular speak). This will attempt to send the commands to all the devices at the same time and to ask Alexa apis to run them in parallel. It is important, you send the commands near the same time (ie in a loop for example), as if they are too far apart when they send, ES would have already sent some, then have to send more (which inherently would lose any coordination you intended).
The messages should not be too long, ~400 chars, as otherwise ES will have to break it up and things will not give the desired 'near simultaneous' output
this should work for zone device and regular device (I would not include the same device twice in a single 'timeframe')
Example:
I have 4 devices
I could send 4 speak() commands, they would be processed sequentially by Alexa. So device A would speak, then b, then c, then d. There may be a small bit of overlap, but you will hear them sequentially
I could send 4 parallelSpeak() commands, if I did this 'at the same time', ES will put them together and send a single command to Alexa with 4 subcommands, and ask Alexa to run them in parallel. The devices should speak near the same time (there may be some skew due to network or Alexa processing, but pretty close)
If I send 4 parallelSpeak commands, but they are timing skewed that they are actually issued 2, then say 1 second, then 2 more, you are likely to hear 2 speak together, then the other two speak together. So it is important they be sent 'back to back' or within a short time of each other
Thanks for this. In the case of a single Rule Machine speak command to multiple echoes, does the command parse to the above, i.e. four sequential ES Speak commands?
I'm thinking the (new) best practice would be to substitute the above single RM command to instead use successive Custom Actions using parallelSpeak commands to each echo. Am I getting the drift of how to use this capability?
Your simple choices are
ParallelSpeak to a zone virtual device or announcement to zone virtual device
From rm or webcore
If an action can do what you want it can also send to multiple zones in addition to a single zone
More complex:
- if you have your own set of devices, you can send parallel speak to each device (within a short time, and ES will combine them together if it can).
Tony has pushed an update that fixes:
- race condition causing some commands to not execute
- further quieting of logging
Regarding Docker instructions, here's my post from v3, no changes need for v4: https://community.hubitat.com/t/release-echo-speaks-v3-actions/22879/1071. Don't forget to git pull origin
the next time the server needs an update!
