[BETA] Apollo Automation AIR-1 Driver
Apollo Automation AIR-1 Driver for Hubitat Elevation
This driver connects your Apollo Automation AIR-1 sensor directly to your HE hub thanks to the great work done by Jonathan Bradshaw (@jonathanb) - the ESPHome Hubitat Toolkit.
The driver can be installed using the community Hubitat Package Manager app or manually as a Bundle archive from GitHub.
  • :prohibited: No Home Assistant Needed: Direct WiFi connection to your Hubitat hub
  • :prohibited: No YAML Files to Edit: Simple IP address configuration - that's it!
  • :prohibited: No Cloud Dependencies: Everything runs locally on your network
  • :high_voltage: Easy Setup: Install this driver package from HPM (Hubitat Package Manager), connect the device to your WiFi network, configure the IP address in the driver - done.
  • :wrench: Zero Configuration: All device features work out-of-the-box
  • :house: Native Hubitat Integration: Full support for Hubitat automations, dashboards, and apps
Technical Specifications (click to expand)
  • Microcontroller: ESP32 with WiFi and Bluetooth
  • Power: USB-C 5V (mains powered)
  • Air Quality Sensors: SEN55 multi-sensor (PM, VOC, NOx, T, RH)
  • Gas Sensors: ENS160 (CO, NH₃, C₂H₅OH, H₂, CH₄, NO₂)
  • CO₂ Sensor: SCD40 NDIR sensor (400-40,000 ppm)
  • Pressure Sensor: DPS310 (300-1200 hPa)
  • Particulate Matter: PM1, PM2.5, PM4, PM10 detection
  • VOC Detection: Volatile Organic Compounds index
  • NOx Detection: Nitrogen Oxides index
  • Operating Range: -40°C to +85°C (-40°F to +185°F)
  • Connectivity: WiFi 802.11 b/g/n, Bluetooth 4.2
  • Dimensions: Compact desktop air quality monitor
  • Mounting: Desktop stand with optional wall mount
Use Cases (click to expand)
The Apollo Automation AIR-1 is ideal for:
  • Indoor Air Quality Monitoring: Comprehensive air quality assessment for homes and offices
  • HVAC Optimization: Monitor air quality to control ventilation and filtration systems
  • Health Monitoring: Track pollutants and allergens for respiratory health
  • Smart Home Automation: Automate air purifiers, fans, and windows based on air quality
  • Office Environment: Monitor CO₂ levels and air quality in workspaces
  • Kitchen Monitoring: Detect cooking fumes and gas levels
  • Allergen Detection: Monitor particulate matter and VOCs that affect allergies
  • Energy Efficiency: Optimize HVAC operation based on actual air quality needs
  • Sleep Quality: Monitor bedroom air quality for optimal sleep environment
AIR-1 Main Device Apollo AIR-1 Features:
• ESP32-based platform with WiFi and Bluetooth connectivity
• Mains-powered operation (USB-C 5V)
• SEN55 Multi-Sensor: PM1/PM2.5/PM4/PM10, VOC, NOx, Temperature, Humidity
• ENS160 Gas Sensor: CO, NH₃, Ethanol, H₂, CH₄, NO₂
• SCD40 CO₂ Sensor: 400-40,000 ppm NDIR detection
• DPS310 Pressure Sensor: Barometric pressure monitoring
• RGB LED indicator with air quality status colors
• Temperature Range: -40°C to +85°C (-40°F to +185°F)
• Comprehensive air quality monitoring for smart homes
Apollo Automation is a local tech startup building advanced hardware and software in Lexington, KY.
Made for ESPHome
:sparkles:Apollo Automation devices come pre-flashed with ESPHome firmware - just connect your AIR-1 to your WiFi network and add the device IP address in the Preferences tab of this driver. No additional software, bridges, or complex configurations required.
Driver Description
The Apollo Automation AIR-1 driver provides comprehensive air quality monitoring capabilities with dozens of available attributes. For everyday use, the driver displays only the essential air quality attributes by default, keeping your device interface clean and focused. Advanced users can enable additional diagnostic attributes through the preferences when needed.
Main Attributes
Commands and Attributes Overview
  • carbonDioxide: CO₂ concentration from SCD40 sensor (400-40,000 ppm)
  • temperature: Primary temperature reading from SEN55 sensor
  • humidity: Relative humidity from SEN55 sensor (0-100% RH)
  • pressure: Barometric pressure from DPS310 sensor (hPa)
  • pm1: PM <1µm weight concentration (µg/m³)
  • pm25: PM <2.5µm weight concentration (µg/m³)
  • pm4: PM <4µm weight concentration (µg/m³)
  • pm10: PM <10µm weight concentration (µg/m³)
  • sen55Voc: VOC (Volatile Organic Compounds) index
  • sen55Nox: NOx (Nitrogen Oxides) index
  • vocQuality: VOC quality text rating (Good, Fair, Poor, etc.)
  • networkStatus: Connection status ['connecting', 'online', 'offline']
  • online: Device online status from ESPHome ['true', 'false']
  • rgbLight: RGB LED control ['on', 'off']
Advanced Attributes
These advanced attributes, disabled by default, provide additional insights and control for power users seeking enhanced functionality.
Complete Attribute List (click to expand)
Attribute Type Description
carbonDioxide number CO₂ concentration (ppm) from SCD40 sensor
temperature number Primary temperature reading (°C/°F)
humidity number Relative humidity percentage
pressure number Barometric pressure (hPa)
pm1 number PM <1µm weight concentration (µg/m³)
pm25 number PM <2.5µm weight concentration (µg/m³)
pm4 number PM <4µm weight concentration (µg/m³)
pm10 number PM <10µm weight concentration (µg/m³)
sen55Voc number SEN55 VOC index
sen55Nox number SEN55 NOx index
vocQuality string VOC quality text rating
networkStatus enum Device connection status
online enum Device online status from ESPHome
rgbLight enum RGB LED control
rtt number Round-trip time measurement (ms)
ammonia number Ammonia (NH₃) gas concentration
carbonMonoxide number Carbon Monoxide (CO) gas concentration
ethanol number Ethanol (C₂H₅OH) gas concentration
hydrogen number Hydrogen (H₂) gas concentration
methane number Methane (CH₄) gas concentration
nitrogenDioxide number Nitrogen Dioxide (NO₂) gas concentration
sen55TemperatureOffset number SEN55 temperature calibration offset
sen55HumidityOffset number SEN55 humidity calibration offset
pm03To1 number PM 0.3 to 1 µm concentration
pm1To25 number PM 1 to 2.5 µm concentration
pm25To4 number PM 2.5 to 4 µm concentration
pm4To10 number PM 4 to 10 µm concentration
espTemperature number ESP32 chip temperature
uptime string Device uptime since last restart
rssi number WiFi signal strength (dBm)
preventSleep enum Sleep prevention control
sleepDuration number Sleep duration in minutes
Commands
  • initialize() - Establishes connection to the device and starts monitoring. Automatically called during device setup or manually from device commands.
  • refresh() - Refreshes device information and clears cached data. Manually refresh device status and request updated information from the device.
  • setRgbLight(value) - Control the RGB LED indicator. Parameters: value ['off', 'on']. Usage: setRgbLight('on') or setRgbLight('off')
  • espReboot(value) - Restart the ESP32 device. Parameters: value ['reboot']. Usage: espReboot('reboot')
  • ping(value) - Measure network round-trip time to device. Parameters: value ['ping']. Usage: ping('ping'). Updates rtt attribute with response time in milliseconds.
  • calibrateScd40(value) - Calibrate CO₂ sensor to 420ppm (outdoor air reference). Parameters: value ['calibrate']. Usage: calibrateScd40('calibrate')
  • cleanSen55(value) - Initiate SEN55 sensor cleaning cycle. Parameters: value ['clean']. Usage: cleanSen55('clean')
  • refreshSensors(value) - Refresh all sensors and bypass thresholds temporarily. Parameters: value ['refresh']. Usage: refreshSensors('refresh'). Forces immediate sensor readings regardless of threshold settings, with events marked [Refresh].
Preferences
Preferences Overview
Basic Settings
  • logEnable (false) - Enable debug logging for troubleshooting
  • txtEnable (true) - Enable descriptive text logging
  • ipAddress (required) - Device IP address for ESPHome API connection
  • sen55TemperatureOffset (0.0) - SEN55 temperature calibration offset (-70° to +70°)
  • sen55HumidityOffset (0.0) - SEN55 humidity calibration offset (-70% to +70%)
Reporting & Thresholds
  • maxReportingInterval (1800) - Maximum time between sensor reports in seconds (60-14400, default: 30 minutes)
  • temperatureChangeThreshold (0.3) - Minimum temperature change to report in degrees (0-2°)
  • humidityChangeThreshold (1.0) - Minimum humidity change to report in percent (0-5%)
  • pmChangeThreshold (0.5) - Minimum PM concentration change to report in µg/m³ (0-2)
  • co2ChangeThreshold (10) - Minimum CO₂ change to report in ppm (5-50)
  • pressureChangeThreshold (0.5) - Minimum pressure change to report in hPa (0-2)
  • vocNoxChangeThreshold (2) - Minimum VOC/NOx index change to report (1-10)
  • gasChangeThreshold (5.0) - Minimum gas concentration change to report in ppb (1-20)
Advanced Options
  • password (optional) - Device password if required
  • diagnosticsReporting (false) - Enable reporting of diagnostic attributes
  • sleepDuration (5) - Sleep duration between measurements (0-800 minutes)
  • logWarnEnable (false) - Enable warning and info logging
Intelligent Reporting System
The driver features an advanced threshold-based reporting system that prevents log spam while ensuring important changes are captured:
Threshold-Based Reporting
  • Smart Filtering: Only reports sensor changes that exceed configurable thresholds
  • Customizable Thresholds: Individual threshold settings for each sensor type
  • Maximum Interval: Guarantees at least one report every 30 minutes (configurable)
  • Event Indicators: Clear suffixes show why each event was reported:
    • [MaxReportingInterval] - Reported due to time elapsed
    • [Refresh] - Reported due to manual refresh command
Benefits
  • Reduced Log Spam: Eliminates unnecessary frequent updates
  • Important Changes Captured: Significant sensor changes are always reported
  • Guaranteed Updates: Maximum interval ensures regular status updates
  • Manual Override: refreshSensors command bypasses thresholds for immediate readings
More info on this driver
Driver Features & Technical Details (click to expand)
The driver uses an intelligent entity management system that:
  • Automatically discovers all available ESPHome entities
  • Maps entities to appropriate Hubitat attributes
  • Handles missing entities gracefully (device variants may not have all sensors)
  • Provides diagnostic control - technical attributes can be hidden from main device view
  • Supports calibration - offset values sync between Hubitat preferences and ESPHome
  • Common Library Integration - leverages the Apollo Common Library for shared functionality across all Apollo device drivers, ensuring consistent behavior and simplified maintenance
The driver provides comprehensive air quality monitoring:
  • Multi-Sensor Integration: Combines particulate matter, gas, CO₂, and environmental sensors
  • Intelligent Reporting: Threshold-based system prevents log spam while capturing important changes
  • Automatic Unit Conversion: Converts between Celsius and Fahrenheit based on hub settings
  • Calibration Support: Individual offset adjustments for temperature and humidity sensors
  • Real-time Monitoring: Continuous monitoring with configurable sleep intervals
  • Standard Compliance: Uses Hubitat standard capability attributes for seamless integration
Environmental Monitoring
For complete indoor air quality tracking:
  • Particulate Matter: PM1, PM2.5, PM4, PM10 concentration monitoring
  • Gas Detection: Six different gas sensors (CO, NH₃, C₂H₅OH, H₂, CH₄, NO₂)
  • Air Quality Indices: VOC and NOx indices with quality ratings
  • Environmental Conditions: Temperature, humidity, and barometric pressure
  • Standard Attributes: Uses Hubitat standard capability attributes (temperature, humidity, pressure)
  • Visual Indicators: RGB LED for air quality status notifications
Sensor Calibration
For accurate readings and optimal performance:
  • CO₂ Calibration: Manual calibration to 420ppm outdoor air reference
  • Temperature Offset: Adjustable temperature calibration for SEN55 sensor
  • Humidity Offset: Adjustable humidity calibration for SEN55 sensor
  • Sensor Cleaning: Automated SEN55 cleaning cycle for maintenance
  • Factory Reset: Complete device reset capability
Network Monitoring
  • Connection Status: Real-time online/offline status
  • Signal Strength: WiFi RSSI monitoring
  • Round-Trip Time: Measure network latency with ping command
  • Enhanced Status: Improved online/offline detection
  • Automatic Reconnection: Built-in ESPHome API reconnection logic
Diagnostic Features
When diagnostic reporting is enabled:
  • ESP32 Monitoring: Internal chip temperature and performance
  • Uptime Tracking: Device restart and reliability monitoring
  • Network Diagnostics: Round-trip time monitoring and connection quality
  • Enhanced Status Reporting: Improved online/offline detection and reporting
  • Configuration Access: View advanced device settings
  • Calibration Values: View all sensor offset parameters
  • Raw Sensor Data: Access to detailed particulate matter size distributions
  • Threshold Control: Individual threshold settings prevent log spam while ensuring important data is captured
Air Quality Automation
The device supports comprehensive air quality automation:
  • HVAC Control: Automate ventilation based on CO₂ and air quality
  • Air Purifier Control: Trigger air purifiers based on particulate matter levels
  • Window/Fan Control: Automate natural ventilation based on indoor vs outdoor conditions
  • Health Alerts: Notifications for poor air quality conditions
  • Energy Optimization: Smart HVAC operation based on actual air quality needs
  • Visual Status: RGB LED indicates current air quality status
Reserved.
thanks. I'll be using it soon.
Coming next :
Nice! Here I was looking at the Apollo page and eyeing the mmwave options. I like the MTR-1 as a device. I am really impressed by the graph that shows the detections, although I am not sure that the Hubitat can render something like that?
I would like to contribute by pump-1 driver. Is it perfect no. Most things work correctly, I haven’t had a chance to fix the auto refill but that is more for the beta firmware.
Also the firmware flash is not right yet.
Try it out and let me know your thoughts.
 * Apollo Automation PUMP-1 Native ESPHome Driver for Hubitat
 * Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 * in compliance with the License. You may obtain a copy of the License at:
 * http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 * on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 * for the specific language governing permissions and limitations under the License.
 * Protocol Conformed to Official Specifications: https://wiki.apolloautomation.com
 * Revision History:
 * v1.3.1 - Fixed firmware OTA endpoint (/perform). Fixed SSE EventStream timeout handling to catch native Hubitat drop states.
metadata {
    definition (name: "Apollo Automation PUMP-1 ESPHome", namespace: "Languy99", author: "Community") {
        capability "Switch"
        capability "Refresh"
        capability "Initialize"
        capability "Sensor"
        capability "TemperatureMeasurement"
        // Apollo Native Fluid Sensors
        attribute "fluidInput", "string"       // "Wet" or "Dry"
        attribute "fluidOutput", "string"      // "Wet" or "Dry"
        // Runtime Variables
        attribute "pumpRunTime", "number"
        attribute "maxSafeRunTime", "number"
        // Config Toggles
        attribute "autoRefill", "string"
        attribute "invertWaterLogic", "string"
        attribute "stopPumpWhenInputDry", "string"
        attribute "stopPumpWhenOutputWet", "string"
        attribute "pumpSafetyOverride", "string"
        // Onboard LED & System Update Tracking
        attribute "ledPower", "string"         // "on" or "off"
        attribute "firmwareUpdateStatus", "string"
        // Diagnostics
        attribute "connectionStatus", "string"
        attribute "rssi", "number"
        attribute "uptime", "number"
        // Custom Apollo Routine Commands
        command "runPump"
        command "runPumpUntilOutputWet"
        command "rebootDevice"
        command "updateFirmware"
        command "setLEDPower", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Onboard status NeoPixel"]]
        command "setLEDColor", [[name:"red*", type: "NUMBER", description: "Red channel (0-255)"], [name:"green*", type: "NUMBER", description: "Green channel (0-255)"], [name:"blue*", type: "NUMBER", description: "Blue channel (0-255)"]]
        command "setPumpRunTime", [[name:"seconds*", type: "NUMBER", description: "Standard execution runtime in seconds"]]
        command "setMaxSafeRunTime", [[name:"seconds*", type: "NUMBER", description: "Maximum safety cutoff threshold in seconds"]]
        command "setAutoRefill", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Auto Refill Logic"]]
        command "setInvertWaterLogic", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Inverted Sensors"]]
        command "setStopPumpWhenInputDry", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Dry Supply Cutoff"]]
        command "setStopPumpWhenOutputWet", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Full Destination Cutoff"]]
        command "setPumpSafetyOverride", [[name:"state*", type: "ENUM", constraints: ["on", "off"], description: "Toggle Hardware Protections"]]
    preferences {
        input name: "deviceIp", type: "string", title: "PUMP-1 IP Address", description: "e.g. 192.168.100.22", required: true
        input name: "pumpEntityId", type: "string", title: "Pump Control Entity ID", description: "Default is switch-pump_control", defaultValue: "switch-pump_control", required: true
        input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
        input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
def installed() {
    log.info "Apollo PUMP-1 Driver Installed"
    initialize()
def updated() {
    log.info "Apollo PUMP-1 Preferences updated"
    unschedule()
    initialize()
def initialize() {
    if (!deviceIp) {
        log.warn "IP Address is not configured. Please check device preferences."
        return
    if (logEnable) log.debug "Connecting to Apollo PUMP-1 SSE Event Stream at http://${deviceIp}/events"
    sendEvent(name: "connectionStatus", value: "connecting")
    try {
        interfaces.eventStream.close()
        interfaces.eventStream.connect("http://${deviceIp}/events")
    } catch (Exception e) {
        log.error "Failed to connect to ESPHome event stream: ${e.message}"
        sendEvent(name: "connectionStatus", value: "disconnected")
        runIn(60, initialize)
def refresh() {
    if (logEnable) log.debug "Stream-based refresh triggered. Re-initializing connection socket..."
    initialize()
    if (!description) return
    def message = description.trim().replaceAll(/\u001B\[[;\d]*m/, "")
    if (message.startsWith("{") && message.endsWith("}")) {
        try {
            def entity = parseJson(message)
            sendEvent(name: "connectionStatus", value: "connected")
            parseEntityData(entity)
        } catch (e) {
            log.error "Failed to parse inline JSON object: ${e}"
    else if (message.startsWith("[") && message.endsWith("]")) {
        if (message.contains('{"id":')) {
            try {
                def entities = parseJson(message)
                if (entities instanceof List) {
                    entities.each { parseEntityData(it) }
            } catch (e) {
                if (logEnable) log.debug "PUMP-1 Log: ${message}"
    else {
        if (logEnable && (message.contains("[D]") || message.contains("[I]") || message.contains("[W]") || message.contains("[E]"))) {
def eventStreamHandler(String message) {
    if (message.startsWith("data:")) {
        parse(message.substring(5))
    } else {
        parse(message)
def parseEntityData(entity) {
    if (!entity || !entity.id) return
    switch(entity.id) {
        // Core Pump Relay Switch
        case "switch-pump_control":
        case "switch-pump_relay":
        case settings.pumpEntityId:
            def switchState = (entity.value == true || entity.state == "ON" || entity.state == "on") ? "on" : "off"
            if (device.currentValue("switch") != switchState) {
                if (txtEnable) log.info "Apollo PUMP-1 Physical Switch turned ${switchState.toUpperCase()}"
                sendEvent(name: "switch", value: switchState)
            break
        // Onboard Status LED
        case "light-rgb_light":
            def ledState = (entity.value == true || entity.state == "ON" || entity.state == "on") ? "on" : "off"
            if (device.currentValue("ledPower") != ledState) {
                if (txtEnable) log.info "Apollo PUMP-1 Status LED reported: ${ledState.toUpperCase()}"
                sendEvent(name: "ledPower", value: ledState)
            break
        // Firmware Deployment Tracking
        case "update-firmware":
        case "update-pump_1_firmware":
            def updateState = entity.state ?: (entity.value == true ? "Update Available" : "Up to date")
            sendEvent(name: "firmwareUpdateStatus", value: updateState)
            break
        // Fluid Input Sensor (Supply Bottle)
        case "binary_sensor-fluid_input":
            def inputState = (entity.state == "Wet" || entity.value == true || entity.state == "ON") ? "Wet" : "Dry"
            if (device.currentValue("fluidInput") != inputState) {
                if (txtEnable) log.info "Apollo PUMP-1 Fluid Input Sensor reported: ${inputState.toUpperCase()}"
                sendEvent(name: "fluidInput", value: inputState)
            break
        // Fluid Output Sensor (Target Reservoir)
        case "binary_sensor-fluid_output":
            def outputState = (entity.state == "Wet" || entity.value == true || entity.state == "ON") ? "Wet" : "Dry"
            if (device.currentValue("fluidOutput") != outputState) {
                if (txtEnable) log.info "Apollo PUMP-1 Fluid Output Sensor reported: ${outputState.toUpperCase()}"
                sendEvent(name: "fluidOutput", value: outputState)
            break
        // Configurable Timing Numbers
        case "number-pump_run_time":
            def rTime = entity.value != null ? entity.value.toInteger() : entity.state.toInteger()
            sendEvent(name: "pumpRunTime", value: rTime, unit: "s")
            break
        case "number-max_safe_run_time":
            def mTime = entity.value != null ? entity.value.toInteger() : entity.state.toInteger()
            sendEvent(name: "maxSafeRunTime", value: mTime, unit: "s")
            break
        // On-board Automation State Logic Registers
        case "switch-auto_refill":
            sendEvent(name: "autoRefill", value: (entity.value == true || entity.state == "ON") ? "on" : "off")
            break
        case "switch-invert_water_logic":
            sendEvent(name: "invertWaterLogic", value: (entity.value == true || entity.state == "ON") ? "on" : "off")
            break
        case "switch-stop_pump_when_input_dry":
            sendEvent(name: "stopPumpWhenInputDry", value: (entity.value == true || entity.state == "ON") ? "on" : "off")
            break
        case "switch-stop_pump_when_output_wet":
            sendEvent(name: "stopPumpWhenOutputWet", value: (entity.value == true || entity.state == "ON") ? "on" : "off")
            break
        case "switch-pump_safety_override":
            sendEvent(name: "pumpSafetyOverride", value: (entity.value == true || entity.state == "ON") ? "on" : "off")
            break
        // Core Diagnostics
        case "sensor-rssi":
            def rssiVal = entity.value != null ? entity.value.toInteger() : entity.state.toInteger()
            sendEvent(name: "rssi", value: rssiVal, unit: "dBm")
            break
        case "sensor-esp_temperature":
            def tempVal = entity.value != null ? entity.value.toBigDecimal() : entity.state.toBigDecimal()
            sendEvent(name: "temperature", value: tempVal, unit: "°C")
            break
        case "sensor-uptime":
            def uptimeVal = entity.value != null ? entity.value.toInteger() : entity.state.toInteger()
            sendEvent(name: "uptime", value: uptimeVal, unit: "s")
            break
// Main Pump Switches
def on() {
    def targetId = (settings.pumpEntityId && settings.pumpEntityId != "switch-pump_relay") ? settings.pumpEntityId : "switch-pump_control"
    executeEsphomeCommand(targetId, "turn_on")
def off() {
    executeEsphomeCommand(targetId, "turn_off")
// Onboard LED Management
def setLEDPower(String state) {
    if (logEnable) log.debug "Setting onboard LED state to: ${state}"
    executeEsphomeCommand("light-rgb_light", state == "on" ? "turn_on" : "turn_off")
def setLEDColor(BigDecimal red, BigDecimal green, BigDecimal blue) {
    if (logEnable) log.debug "Setting onboard LED color to R:${red} G:${green} B:${blue}"
    executeEsphomeCommand("light-rgb_light", "turn_on", [r: red.toInteger().toString(), g: green.toInteger().toString(), b: blue.toInteger().toString()])
// Firmware Maintenance Controls (Updated to ESPHome native /perform endpoint)
def updateFirmware() {
    log.info "Triggering native ESPHome OTA routine via /perform. If update fails to clear, access web flasher at https://flash.apolloautomation.com or update manually at http://${deviceIp}/update"
    executeEsphomeCommand("update-firmware", "perform")
    executeEsphomeCommand("update-pump_1_firmware", "perform")
// Custom Execution Commands
def runPump() {
    if (logEnable) log.debug "Executing Action: Run Pump"
    executeEsphomeCommand("button-run_pump", "press")
def runPumpUntilOutputWet() {
    if (logEnable) log.debug "Executing Action: Run Pump Until Output Wet"
    executeEsphomeCommand("button-run_pump_until_output_wet", "press")
def rebootDevice() {
    if (logEnable) log.debug "Executing Action: ESP Reboot"
    executeEsphomeCommand("button-esp_reboot", "press")
def setPumpRunTime(BigDecimal seconds) {
    executeEsphomeCommand("number-pump_run_time", "set", [value: seconds.toString()])
def setMaxSafeRunTime(BigDecimal seconds) {
    executeEsphomeCommand("number-max_safe_run_time", "set", [value: seconds.toString()])
def setAutoRefill(String state) { executeEsphomeCommand("switch-auto_refill", state == "on" ? "turn_on" : "turn_off") }
def setInvertWaterLogic(String state) { executeEsphomeCommand("switch-invert_water_logic", state == "on" ? "turn_on" : "turn_off") }
def setStopPumpWhenInputDry(String state) { executeEsphomeCommand("switch-stop_pump_when_input_dry", state == "on" ? "turn_on" : "turn_off") }
def setStopPumpWhenOutputWet(String state) { executeEsphomeCommand("switch-stop_pump_when_output_wet", state == "on" ? "turn_on" : "turn_off") }
def setPumpSafetyOverride(String state) { executeEsphomeCommand("switch-pump_safety_override", state == "on" ? "turn_on" : "turn_off") }
// Unified URL construction helper for native ESPHome interactions
private def executeEsphomeCommand(String entityId, String command, Map queryParams = null) {
    def componentType = entityId.split("-")[0]
    def normalizedId = entityId.replace("${componentType}-", "")
    def targetUri = "http://${deviceIp}/${componentType}/${normalizedId}/${command}"
    def params = [
        uri: targetUri,
        timeout: 5
    if (queryParams) {
        params.query = queryParams
    if (logEnable) log.debug "Sending ESPHome Command to ${targetUri} with query params: ${params.query ?: 'None'}"
    def logUri = targetUri
    if (queryParams) {
        def queryString = queryParams.collect { k, v -> "${k}=${v}" }.join("&")
        logUri += "?${queryString}"
    asynchttpPost("commandResponseHandler", params, [uri: logUri])
def commandResponseHandler(response, data) {
    if (response.hasError()) {
        log.error "PUMP-1 Endpoint Control Failure at [${data?.uri}]: ${response.getErrorMessage()}"
// Re-engineered to properly intercept native Hubitat system stream drops
def eventStreamStatus(String status) {
    log.warn "SSE Event Stream Status changed to: ${status}"
    if (status && status.startsWith("START")) {
    } else {
        unschedule(initialize)
        // Auto-reconnect after 10-second cool down following an error or timeout exception
        runIn(10, initialize)
