Best way to learn groovy?
Any suggestions on where to start with learning groovy? Just looking for a basic overview of how it works in the context of device handlers, exposing capabilities, and making commands available. I have a number of devices that aren't fully functional (as do we all). Not looking to become a releasing developer. Just to be able to read and update my own system.
Are you a code slinger already? Do you know other languages? Java?
If so, I'd start with a review of Smartthings development documentation. It translates very well to HE. Groovy in and of its self won't get you the knowledge of the platform on which it's being used. I approached learning it from the point of what do I want to accomplish and just looking up how to do it and working outward from there.
You can also reference the Groovy documentation itself to uncover little bits.
http://groovy-lang.org/documentation.html#gettingstarted
If not, you might want to start with the basics of object oriented programming before tackling a specific language.
I'm still learning as well, but Smart Things has some tutorials including Groovy and writing apps and drivers. I assume not 100% is applicable to HE, but it's not a bad place to start.
https://docs.smartthings.com/en/latest/getting-started/groovy-for-smartthings.html#groovy-for-smartthings
https://docs.smartthings.com/en/latest/getting-started/first-smartapp.html
I've learned a number of programming languages by hacking around in code. Most languages I find are similar in many ways and I just use google when I'm not sure of the exact syntax as I get them mixed up a lot of the time.
I learned the driver specific stuff by poking around in simple drivers in both SmartThings and Hubitat. Once I learned the simple stuff the rest of the stuff started to make sense. The documentation is great for understanding commands too. But look at a lot of other code for examples on how to do certain stuff.
Thanks all. I wouldn't call myself a code slinger. More like a "pieces putter togetherer".
Yeah I'm only interested in learning the format within the context of HE/ST.
Is it possible to have access to the code for the built-in drivers on the HE hub just for study purposes? Only curious about them because they were written by HE staff and probably all follow a similar format.
Groovy reminds me of python coding.
I agree 100%
