Greetings to all.
Could any one please advise the best and cost effective TTS device that I can use with HE?
Tito
Greetings to all.
Tito
Depends on what you mean by "best." There are many options:
Personally, I'm using LANnouncer for the rare instance where I want TTS. It works pretty well aside from the minor tablet-sleeping issues (I think Fully Kiosk Browser, also used by many people for dashboards, now has support for TTS, so it might work better than LANnouncer since if the tablet is always on, the app will likely always be in the foreground, but I haven't tried this and I'm not sure if anyone has written Hubitat code for this yet). If I weren't already deep in the Amazon ecosystem, I'd consider the Google Home family of products (but if you find one for cheap you could always just get one anyway and mute the mic--I've heard they're good even if announcements and whantot is all you use them for). And if I didn't think it were a lot more money than I'd want to spend, I'd definitely do Sonos.
...and there are probably even more options that I don't know about. These are just ones I'm aware of because I've considered most.
Thanks Bertabcd1234 for your quick and detailed response. I appreciate your time. Now I got some idea to start with. Thanks again. Regards, Tito
I havenβt touched my install of it in a couple months, and the only issues I have are when an Echo jumps off the network completely or needs a reboot (only once or twice). I just assumed development stopped because it was working so well
Thanks Adamkempenich for the updated information.
This driver was ported. It works well and also it can cast (not that that's needed now that Chromecast integration is available), but it's an easy interface once you get it setup. There's a trick to getting cast to work though.
You can use any computer. You just need to run VLC Player on it.
And of course, there's always, MY way...Muahahahah
Thanks SmartHomePrimer for the additional information. I like it.they are very helpful for learning for me. Let me try all the options. Thanks again
