I have the a BeSense Motion Sensor Zwave Plus. When I installed it, Hubitat recognized it and set it to use the correct driver.
Motion works as expected. However, I cannot change the Alarm Elimination Time or the PIR LED Enabled settings.
I'm new to Hubitat so it could simply be user error. I've tried just about everything I could think of but the configurations never change. The logs show the system setting the values but they don't seem to take.
Haha sorry I never responded. Thanks for the help, the tamper switch worked.
@leeonestop - This is a great motion sensor. I use it in the kitchen to turn lights on and off. No issues whatsoever. I have it mounted on the ceiling. It's a little bigger than I expected.
I also have several ofthe Zooz ZSE40 4 in 1 sensors (see link below) that are smaller and work better for me in my configuration. I particularly like the fact that these report temperature and humidity data. I use them in conjunction with the Ecobee lite instead of their extra temperature sensors.
But if you're just needing motion, the BeSense is terrific.
I use the BeSense in my kitchen without any issues for more than a year now. I did have to replace the two AA batteries, but that's because I had it in testing mode for quite a long time... I was lazy and didn't want to get up on the latter to reset it hehe.
