With a few of my own modifications (robots report battery for instance that is unhandled). If you want I can send my driver over and you can compare and merge whatever changes you want. Technically the battery report is not "unhandled" it just reports as a warning iirc in the logs, and I wanted to use that data, so I added it modeling the other parameters.
