Just bought my first C7 off Ebay and I also bought a Minoston MP31ZP off Amazon. I was able to pair it but it doesn't show any state and when I try to update the device Type I get a 500 error. Not quite sure what is going on. My hub and zwave driver are on the latest, 2.3.8.124 and 7.18.1 respectively.
I can't include links or pictures yet so here's some copy paste.
| Stats | Status | Actions | Device Class | Device | Security | Route |
| 0x0c (012) | PER: 0, RTT Avg: 8ms, LWR RSSI: 20dB | |||||
| Neighbors: 2, Route Changes: 1 | RefreshRepair | GENERIC_TYPE_SWITCH_BINARY | ||||
| NIE Technology Co., Ltd | [Outlet ] | None | 01 -> 0C 40kbps |
Error 500
Something went wrong
If you are seeing this screen repeatedly, please visit .
Welcome to the platform and to the community. There is nothing that you are doing wrong. Seems that 2.3.8.124 has a bug being seen by many, on most if not all devices. Just wait a bit and the elves will issue a fix.
See this thread.
If you go to settings tab and do a check for updates, the hub probably will let you to downgrade to the previous release. There is a warning about it being a downgrade, but it should be no issue to do so.
I would do so until they fix this bug in 2.3.8.124 release.
Thanks both of you! I ended up downgrading and was able to modify the device type after to make it functional. Appreciate the quick reply
Welcome! If you join the "Owners" group here in the community (in your user profile settings), that'll enable posting screenshots. It's just a measure to cut down on bot-related new-account spam & shenanigans.
Glad you were able to work around. Now you can upgrade to .125, which was just released that fixes the problem you encountered yesterday:
