Oh, nice...I used to live somewhat near there. That's a cool area.
Sorry to hear that about Bali support. I'm always worried that I'll hit a wall with support when I'm not following their "approved" path. That's part of the reason I haven't gotten in touch with them on my issue. (Plus, to their point, my issue actually didn't happen with SmartThings, but I'm sticking with Hubitat.
Good call on migrating more devices, I'd think. It seems like the additional repeaters should help, though I'm no Z-Wave expert...I'm sure others will chime in on that.
As far as repeaters near my "problem child", there's just the other wall-powered shade that's about 6-8 feet away, but ironically, my problem shade is the closest device to my hub (about 15 feet line-of-sight).
Sure, I'm just using the Z-Wave Shade driver that @DeveloperDavidB has posted before, with the modified parse() routine below. (I apologize in advance for the code. This could probably be done better/easier, but I'm still learning Groovy.)
def result = null
def hexVal = null
def movingHex = null
if (description != "updated") {
log("parse() >> zwave.parse($description)", "DEBUG")
if(description.trim().endsWith("payload: 00 00 00")) {
sendEvent(name: "level", value: 0, unit: "%")
log("Shade is down, setting level to 0%.", "DEBUG")
} else if(description.contains("command: 2603")) {
if(description.contains("isMulticast")) {
log("Detected isMulticast string", "DEBUG")
def mcastIdx = description.lastIndexOf(",")
def dummyStr = description.substring(0,mcastIdx)
hexVal = dummyStr.trim()[-8..-7]
movingHex = dummyStr.trim()[-2..-1]
} else {
hexVal = description.trim()[-8..-7]
movingHex = description.trim()[-2..-1]
log("hexVal = ${hexVal}.", "DEBUG")
try {
def intVal = zigbee.convertHexToInt(hexVal)
def movingInt = zigbee.convertHexToInt(movingHex)
log("intVal = ${intVal}.", "DEBUG")
if(movingInt == 0) {
log("Shade has stopped.", "INFO")
} else if(movingInt == 254) {
log("Shade is moving.", "INFO")
} else {
log("movingInt = ${movingInt}.", "INFO")
sendEvent(name: "level", value: intVal, unit: "%")
} catch(e) {
log("Exception ${e}", "ERROR")
} else if(description.contains("command: 8003")) {
log("Battery Reported.", "DEBUG")
def cmd = zwave.parse(description, [0x20: 1, 0x26: 1, 0x70: 1])
if (cmd) {
result = zwaveEvent(cmd)
if (result?.name == 'hail' && hubFirmwareLessThan("000.011.00602")) {
result = [result, response(zwave.basicV1.basicGet())]
log("Was hailed: requesting state update", "DEBUG")
} else {
log("Parse returned ${result?.descriptionText}", "DEBUG")
return result
