I presume I can tap off the USB output on these to get 5VDC/2A. Can I "float" the HE hub on the USB tap while it continuously charges? The wall wart on this is listed as 12V/0.5A, so is this enough to keep the battery pack fully charged while the HE runs off the USB tap?
According to the Q&A on the Amazon link, these are supposed to be able to charge at the same time you are pulling power off the USB tap. The concern I have is whether the 12.6V/0.5A wall wart provides enough power to keep the battery fully charged while the HE hub runs off the USB tap.
Hmmm the description of the product says the opposite. Just wanted to point that out. If you purchase the device you can test and as long as it is prime you have a 30 day window to return for full refund.
Yeah, these seem to be sort of odd devices, more power-pack than UPS. It appears that the switch turns off both charging and power output. When the switch is "on" the battery pack can be charged at the same time you draw power from the 12.6V input connector or the 5V USB port.
I stumbled over a thread (now I can't find it) in which someone said they were using one as a cheap UPS for their HE. My concern is that the inexpensive one cannot provide enough power to maintain or restore a battery charge while simultaneously running the HE hub. Its wall wart only puts out about 6 watts.
Got one TalentCell when I was in the states last year.
Does it charge and power the Hub simultaneously, sure does.
Does it seamlessly switch between mains and battery, sure does.
Have I had a power cut, nope, but in my initial testing it held the Hub up for over 30min.
For me, that’s 3 wins.
One free day I might see how long it will keep the Hub running for but that’s not the best thing to do with li-Po batteries, I’m now told.
From the info I've read, a lot of the Anker packs have a short power drop-out when a mains power is cut while another device is being "charged". I'm pretty sure that would cause my HE hub to reboot, and that is exactly what I am trying to prevent.
