Great news @mike.maxwell! I have installed 55 of those Aurora double power sockets in my new house! My move got delayed and I was going to start trying to add the aurora sockets next weekend but I'll wait for the next release if you're planning on adding them to the next release! Let me know if you want me to test the drivers!
I have them. They need a new zigbee 3.0 driver for them to work perfectly as they act a bit different to the standard lamps (all 3 different manufacturers zigbee 3.0 lamps i have do the same ). As @mike.maxwell now has them, once he has time he is going to sort this
The Aurora double sockets? If so, I've added all of them but one of them won't pair (not sure why as it's only marginally further away from the rest of them!). I haven't added any automation rules yet as wanted to get them all added first but you can manually control both sockets independetly and they seem to respond quite well. So far it's a tick from me but it took a while to set them up all up as I was trying to build the strongest ZigBee mesh that I could so I didn't rush adding them. It also takes a while to rename each individual socket but that's the same regardless of which devices you add!
Well, Iβve just ordered a couple of the 4 button controllers to play with.
They should arrive in a few days (hopefully) @mike.maxwell
Mike can all 4 buttons be used with the three commands (push/hold/release) or are they limited like the Hue controller?
I have just joined one and everything worked apart from button 4
No response at all and nothing in the logs to say it got the command or anything at all relating to button 4
I thought I might have a faulty controller, so paired the second one I bought.
this is exactly the same - No functions on Button 4
On both devices the led lights when I press all the buttons (inc button 4)
It seems unlikely that two brand new controllers have the same button 4 fault.
EDIT: No battery is showing yet, does it take a while to report?
The Aurora device is slightly thicker & wider & shorter than the Hue device, but nicely rounded and much nicer to hold - the base plate is about 1.5 times as thick as the Hue base plate at it's thickest part
