My Hub can discover it. No problem- just shows as Device.
Just unsure which driver to use.
How to figure out which button is which.
Then I guess use rule machine or simple lighting app to configure the buttons right?
Any help on what the driver might be.?
And how to go about upgrading the firmware on the device.. without having to buy their hub ?
I have the Kinetic Dimmer Too.. which looks great ( I guess this will be similar process ).
I don't believe that is the correct driver. This remote just came out recently. ST staff is writing a driver for it currently but it has not been released.
But also, it uses Zigbee group messages so likely will not work with Hubitat.
The remote linked above also has CT but the remote you linked to is Switch and level only.
Ok.. shame about the kinetic dimmer..
What is special about the SmartThings hub that allows firmware upgrade that HE can't do.. Is it just a partnership thing ?
FYI, I think Mike featured this device in the last episode of Hubitat Live. It sounded like they'd even be able to write a driver for it, and if it can use group messaging, it's at least somewhat different from the EcoSmart if they are able to do that; see also:
