Sounds like you’ll need to use something like THIS
Thanks for the suggestion, but I really don't want to go down that route.
I am hoping someone will have found a single BC fitting LED bulb that works well with this dimmer.
Quick update. I've been in contact with Aurora and surprisingly they don't make a BC LED bulb that is high enough wattage to work with this dimmer. I've tried another brand 12w dimmable LED bulb and that wouldn't work either. I've also realised that if you have a power outage these come back on at 100%. That is a non starter for me so this is going in the box of failed gadgets for the moment and I'm sticking with my Yagusmart switches.
Shame, as the device has potential, but 90% of my rooms are a single bulb so would need a dummy load adding and one of my hard and fast rules on lighting is that it must not come on after a power outage (we have a few round here and very often at night)
found this in the middle of the night, very low WAF... anyone know if there is an option to set them to off or last state?
edit notied one was on version11 so tried to update but got this error, any way round?
2022-01-25 12:31:00.686 Firmware update for [name:Loft Bedroom Lights, manufacturer:Aurora, imageFileName:121C-1405-0014, fileVersion:0014] failed, the device doesn't support wildcard file parameters.
2022-01-25 12:31:00.630 Starting firmware update for Loft Bedroom Lights, Aurora from 00000011 to 0014.
I've had no luck, the best workaround I can think of (using these specific modules) would be to put them in slave mode so they report in but don't actively control the load, then mirror their action to a dimming module which remembers its last state. Seems overly complicated and expensive.
I suppose another option would be to have something on the lighting circuit (or whole house supply) which is able to report the status of the incoming power, then issue commands to turn off these modules when power is restored.
