If it works on smartthings (i believe all of their range is supported now) it should be easy to port to HE.
They are zigbee 3.0 so they will work with HE they just need the driver ported. You don't need their hub because they will connect direct, the only issue i have heard is that they don't come with the latest firmware. So to get that updated you currently need Aurora's hub or a ST hub to temp connect it to the get the updated firmware.
yeah it's supported and looks like a standard dimmer
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "ZigBee Dimmer", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "oic.d.light", runLocally: true, minHubCoreVersion: '000.019.00012', executeCommandsLocally: true, genericHandler: "Zigbee") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Switch"
capability "Switch Level"
capability "Health Check"
capability "Light"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "LCBulb01UK", deviceJoinName: "Aurora AOne Control Dimmer (120w)", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LEEDARSON LIGHTING", model: "M350ST-W1R-01", deviceJoinName: "OZOM Dimmable LED Smart Light"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300", outClusters: "0003", manufacturer: "Aurora", model: "Dimmer", deviceJoinName: "Aurora AOne Control Dimmer (320w)", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart A19 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY A19 ON/OFF/DIM 10 Year", deviceJoinName: "SYLVANIA Smart 10-Year A19"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FF00", outClusters: "0019", manufacturer: "MRVL", model: "MZ100", deviceJoinName: "Wemo Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05", outClusters: "0019", manufacturer: "OSRAM SYLVANIA", model: "iQBR30", deviceJoinName: "Sylvania Ultra iQ"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY PAR38 ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart PAR38 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B04, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY BR ON/OFF/DIM", deviceJoinName: "SYLVANIA Smart BR30 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G13", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G14", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G23", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-G33", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N13", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N14", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E12-N15", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL6HD", deviceJoinName: "Leviton Dimmer Switch", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL3HL", deviceJoinName: "Leviton Lumina RF Plug-In Dimmer", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "DL1KD", deviceJoinName: "Leviton Lumina RF Dimmer Switch", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B04, 0B05, FC01, FC08", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "A19 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y A19 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "BR30 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y BR30 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0B05, FC01", outClusters: "0003, 0019", manufacturer: "LEDVANCE", model: "PAR38 W 10 year", deviceJoinName: "SYLVANIA Smart 10Y PAR38 Soft White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0003, 0006, 0008, 0019, 0406", manufacturer: "Leviton", model: "ZSD07", deviceJoinName: "Leviton Lumina RF 0-10V Dimming Wall Switch", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0000", deviceJoinName: "Smart Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "LDS", model: "ZHA-DIMLight-GLS0000", deviceJoinName: "Smart Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS", deviceJoinName: "Smart Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0044", deviceJoinName: "Smart Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0009", outClusters: "0019", manufacturer: "Aurora", model: "FWMPROZXBulb50AU", deviceJoinName: "Aurora MPro"
fingerprint profileId: "0104", inClusters: "0000, 0004, 0003, 0006, 0008, 0005, FFFF, 1000", outClusters: "0019", manufacturer: "Aurora", model: "FWBulb51AU", deviceJoinName: "Aurora Smart Dimmable"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "FWStrip50AU", deviceJoinName: "Aurora Dimmable Strip Controller"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Aurora", model: "FWGU10Bulb50AU", deviceJoinName: "Aurora Smart Dimmable GU10"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "Smarthome", model: "S111-201A", deviceJoinName: "Leedarson Dimmable White Bulb A19"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 265", deviceJoinName: "Innr Smart Bulb White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RB 245", deviceJoinName: "Innr Smart Candle White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "innr", model: "RS 225", deviceJoinName: "Innr Smart Spot White"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N13", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E11-N14", deviceJoinName: "Sengled Element Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FEDC", outClusters: "000A, 0019", manufacturer: "LDS", model: "ZBT-DIMLight-GLS0006", deviceJoinName: "Smart Bulb"
**fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "WallDimmerMaster", deviceJoinName: "Aurora Smart Rotary Dimmer", ocfDeviceType: "oic.d.switch"**
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, 0702, 0B05", outClusters: "0019", manufacturer: "sengled", model: "E1A-AC2", deviceJoinName: "Sengled DownLight"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "MLI", model: "ZBT-DimmableLight", deviceJoinName: "Müller Licht Tint Bulb Dimming"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0300, FC0F", outClusters: "0019", manufacturer: "OSRAM", model: "LIGHTIFY Edge-lit flushmount", deviceJoinName: "SYLVANIA SMART+ Flush Mount"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008", outClusters: "0019", manufacturer: "Aurora", model: "NPD3032", deviceJoinName: "Aurora In-line Dimmer", ocfDeviceType: "oic.d.switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0301, FC01", manufacturer: "ubisys", model: "D1 (5503)", deviceJoinName: "INGENIUM ZB Universal Dimming Module ZBM01d"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", manufacturer: "Megaman", model: "AD-DimmableLight3001", deviceJoinName: "INGENIUM ZB LED Classic"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 1000", outClusters: "0019", deviceId: "0101", manufacturer: "AduroSmart Eria", model: "AD-DimmableLight3001", deviceJoinName: "Eria ZigBee Dimmable Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "RF 263", deviceJoinName: "INNR Smart Filament Bulb Vintage"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "BF 263", deviceJoinName: "INNR Smart Filament Bulb Vintage"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000, FC82", outClusters: "0019", manufacturer: "innr", model: "BF 265", deviceJoinName: "Innr Smart Filament Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000", outClusters: "0019", manufacturer: "innr", model: "AE 260", deviceJoinName: "Innr Smart Bulb"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0B05, 1000", outClusters: "0019", manufacturer: "innr", model: "BE 220", deviceJoinName: "Innr Smart Flood Light White"
fingerprint mfr:"innr", model:"RF 265", deviceJoinName: "Innr Smart Filament Bulb White" // raw description: 01 0104 0101 01 09 0000 0003 0004 0005 0006 0008 0B05 1000 FC82 01 0019
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.light.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.light.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch", "refresh"])
// Parse incoming device messages to generate events
log.debug "description is $description"
def event = zigbee.getEvent(description)
if (event) {
if (event.name=="level" && event.value==0) {}
else {
sendEvent(event)
} else {
def descMap = zigbee.parseDescriptionAsMap(description)
if (descMap && descMap.clusterInt == 0x0006 && descMap.commandInt == 0x07) {
if (descMap.data[0] == "00") {
log.debug "ON/OFF REPORTING CONFIG RESPONSE: " + cluster
sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
} else {
log.warn "ON/OFF REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
} else if (device.getDataValue("manufacturer") == "sengled" && descMap && descMap.clusterInt == 0x0008 && descMap.attrInt == 0x0000) {
// This is being done because the sengled element touch/classic incorrectly uses the value 0xFF for the max level.
// Per the ZCL spec for the UINT8 data type 0xFF is an invalid value, and 0xFE should be the max. Here we
// manually handle the invalid attribute value since it will be ignored by getEvent as an invalid value.
// We also set the level of the bulb to 0xFE so future level reports will be 0xFE until it is changed by
// something else.
if (descMap.value.toUpperCase() == "FF") {
descMap.value = "FE"
sendHubCommand(zigbee.command(zigbee.LEVEL_CONTROL_CLUSTER, 0x00, "FE0000").collect { new physicalgraph.device.HubAction(it) }, 0)
sendEvent(zigbee.getEventFromAttrData(descMap.clusterInt, descMap.attrInt, descMap.encoding, descMap.value))
} else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
log.debug "${descMap}"
def off() {
zigbee.off()
def on() {
zigbee.on()
def setLevel(value, rate = null) {
def additionalCmds = []
if (device.getDataValue("model") == "iQBR30" && value.toInteger() > 0) { // Handle iQ bulb not following spec
additionalCmds = zigbee.on()
} else if (device.getDataValue("manufacturer") == "MRVL") { // Handle marvel stack not reporting
additionalCmds = refresh()
zigbee.setLevel(value) + additionalCmds
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
return zigbee.onOffRefresh()
def refresh() {
zigbee.onOffRefresh() + zigbee.levelRefresh()
def installed() {
if (((device.getDataValue("manufacturer") == "MRVL") && (device.getDataValue("model") == "MZ100")) || (device.getDataValue("manufacturer") == "OSRAM SYLVANIA") || (device.getDataValue("manufacturer") == "OSRAM")) {
if ((device.currentState("level")?.value == null) || (device.currentState("level")?.value == 0)) {
sendEvent(name: "level", value: 100)
def configure() {
log.debug "Configuring Reporting and Bindings."
// Device-Watch allows 2 check-in misses from device + ping (plus 1 min lag time)
// enrolls with default periodic reporting until newer 5 min interval is confirmed
sendEvent(name: "checkInterval", value: 2 * 10 * 60 + 1 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
// OnOff minReportTime 0 seconds, maxReportTime 5 min. Reporting interval if no activity
refresh() + zigbee.onOffConfig(0, 300) + zigbee.levelConfig()
so use generic zigbee dimmer
