Correct, I did play with that briefly and was able to get it to speak and then go back to an iHeart Radio station. Yes, it went back to the beginning of the track, as you mention. That is a manageable situation.
I will give the TTS a try later. It would be nice to remove another third party piece from this puzzle. My first swing at using playText seems to cutoff the last syllable.
There are a few other anomalies that I noticed:
- 1 of my 4 Arylic units was not discovered.
- I fumbled around a bit with the master/slave controls. I had volume controls independent on my dashboard, but did not see an easy way to accomplish that. For now, I just kept my separate "dimmer" sliders that send the master-only or slave-only volume commands.
Overall, very cool.
